Intermittent Rattling Noise From Engine
Old May 31, 2012
Digipixel's Avatar
Digipixel is an unknown quantity at this point
1991 Honda Civic LX w/approx. 131K miles.
Got home from work last night and when I pulled into the driveway I heard a loud rattling noise coming from the engine compartment. When I lifted the hood the noise appeared to be coming from the engine block.
I let it sit overnight, then checked the oil this morning before I cranked it. The oil level is fine, and in fact it's slightly above the top mark (hole) in the dipstick. I just had the oil changed about 3 weeks ago. This morning when I cranked it, it made only a slight rattling noise, so I drove it around the neighborhood for a mile a so and the noise went away. I decided to risk driving it to work this morning (about 12 miles from home) and by the time I got to work the engine was purring like a kitten. No sign of a noise.
Any ideas about what I was hearing? A bearing about to go? Timing belt? Loose heat shield? Not sure about how to troubleshoot this one.
Reverend Rick
Old May 31, 2012
Re: Intermittent Rattling Noise From Engine
could be a torn front engine mount.
Old May 31, 2012
Digipixel's Avatar
Thanks gb, I'll check out the front mount.
Old Jun 6, 2012
Digipixel's Avatar
Okay - I just updated another of my posts on the forums regarding my Check Engine light coming on. Turns out it was a bad distributor. The mechanic who replaced the distributor said the bad distributor had metal parts down inside of it like it had started to come apart. It's a wonder the car would run at all!
Now I'm wondering if the bad distributor was making the rattling noise when it started to disintegrate from the inside.
ywgflyer
May 15, 2015 05:05 PM
BootyDo
May 8, 2015 05:36 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
silentbutviolent
Jan 7, 2002 07:35 PM
CaseysGuy385
Dec 26, 2001 01:35 AM
