2002 Civic EX Thump on Drivers Side Floor
Old May 1, 2012
mgslayer's Avatar
mgslayer is an unknown quantity at this point
I have a 2002 4 dr Civic EX 5 spd with 136K miles that started making a thump that I can feel under driver's side, almost directly under my feet when mildly to moderately accelerating. Some days are worse than others. I have since replaced both lower control arms because the rubber was shot, front sway bar end links, front sway bar bushings, front motor mount (torn to shreds), drivers side motor mount, and rear sway bar bushings. Rear trans mount looks to be solid. I didn't replace the rear sway bar end links because I ran out of daylight, so that is on this weeekends plans. Anything else I should check? Lower ball joints were loose but not sloppy, and no extra slop in the wheel bearings. No noise from cv joints when turning. Original front and rear shocks.
Thanks
Mark
CarStuff
Dec 6, 2020 12:52 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ej8
Apr 13, 2015 06:36 PM
CapYoda
Nov 11, 2001 05:17 PM
mwwhonda
Nov 7, 2001 07:24 PM
