Brown coolant?
Old Apr 17, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Brown coolant?
2001 LX Civic sedan, auto trans. 102,000 miles.
Hit by a deer Dec. 23 2011 that took out the radiator.
The trans started slipping last week.
I checked the coolant tonight and the color is brown. The color was green.
The trans fluid is where it has been since I replaced the fluid.
The engine oil level has dropped a little. The oilpan gasket leaks.
From what I have read on a google search the consensus is that the mixture is too weak causing corrosion BUT this engine has an aluminum block NOT an iron block. So that point is moot.
Why is my coolant brown???
Old Apr 19, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Re: Brown coolant?
Anyone?
Is this problem so common that I just need to search better?
Old Apr 19, 2012
MindBomber's Avatar
Live for the Twisties
Re: Brown coolant?
You said you're not losing oil, aside from what would likely be normal as a result of the bad oil pan gasket, but I'll ask this anyway, any brown sludge?
The only possible causes I know for brown coolant are rust (not possible in this case), a blown head gasket, or an improper mix.
Old Apr 19, 2012
Re: Brown coolant?
you either have trans fluid (coming in from the trans cooler inside the radiator) or engine oil in the coolant. it doesnt take much to cause contamination.
Old Apr 19, 2012
Re: Brown coolant?
Or cruddy coolant.
Rust from lack of antifreeze/too much water? That wil turn it brown.
styles234
21
Nov 19, 2019 07:23 AM
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
tooly145
Sep 5, 2015 01:05 AM
