Need sme help 02 civic speedo not working car not taking off in D
hey i have a 2002 civic and a prob i cnt seem to solve jus bought this car on a deal running an evrything but it wont take off in D drive and the speedo isnt working. thought it was the tranny i have a whole engine an tranny out of a next car i swapped the whole engine but it still does the same thing, it shifts fine but it wont take off in D only if i put it in 1 any ideas wud be greatly appreciated
Re: Need sme help 02 civic speedo not working car not taking off in D
Does the D light up on the cluster when the shifter is in Drive?
Does the check engine light work?
Does it have a P0500 code?
What codes DOES it have?
Which codes come right back?
Drive the car with the scanner attached:
Does the scanner show VSS to be working and accurate in the datalist when the car is driven?
Also, make absolutely certain that the trans solenoids don't have the connectors swapped. Check them all. This is real easy to get wrong on many of the trannys.
(If they were wrong before you did the trans, and you put them right back where they were, then they are still wrong. Right?)
HTH
HTH
yea the D light lights up when its in drive but it will be blinking the check engine light works ok i might kinda found piece of the prob whoever worked on this b4 cut the whole harness that runs inside in half an rejoined the wires by twisting them together so i chnged my harness 2day have tested anything as yet i'll keep you posted thanks
It is almost impossible to guess what an idiot could have done.
Sounds like replacing the harness is your best choice at the moment, until you know more.
The whole engine harness?
ok i've replace the harness no the whole harness jus the one that runs to the tcm still doing the same thing got a comp put on it an pulled these codes 01-1 At lockup sol A failure (2) 41-2 ho2s si heater failure (3) 70-2 at system malfunction
So the wiring made some sort of improvement, or difference?
A 2002 doesn't have a separate TCM in the US.
Do you mean the black connector (C) that contains most or all of the trans wiring at the PCM?
Got "P code" format? I can't look up the codes on the Honda site in that format. (01-1 comes up as ABS)
"A/T system malfunction" (P0700, sort of generic for anything trans related) only means there is another trans code, and the dealer tech needs to look in the trans section of the PCM to find it. (The HDS has engine and trans separate.)
Lockup sol fail is incorrect resistance seen by the PCM, so I'd ohm check the solenoid then ohm check the same thing from the PCM connector. To start with.
Also make sure the wires go to the right pins in the PCM connector.
Heater fail is usually a bad O2 sensor, but seeing as how you have hacked wiring, anything is possible.
Same as with the other issue above.
HTH
HTH
mattdoc
Mar 14, 2017 12:10 PM
GH04si
Apr 15, 2015 08:13 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
