01 civic - Idle problem when stopping
Old Apr 2, 2012
ajbias490's Avatar
jdm lifestyle
ajbias490 is an unknown quantity at this point
Unhappy 01 civic - Idle problem when stopping
When I come to a stop the idle drops for a few seconds like its gonna die then increases back to normal. Can anyone give me an idea of why this could be happening? Its an 01 civic ex with a manual tranny. Thanks
Old Apr 2, 2012
GolNat's Avatar
Prelude Owner
Re: 01 civic - Idle problem when stopping
Your IAC valve is probably dirty, I would clean that first. Read this, it will tell you how to take it off and clean it. It's easy:
https://www.civicforums.com/forums/1...?highlight=diy
Old Apr 2, 2012
ajbias490's Avatar
jdm lifestyle
We already tried cleaning it and it didn't help. Maybe I should replace it?
Old Apr 3, 2012
GolNat's Avatar
Prelude Owner
I don't think you need to replace it. I have an 01 Lx, and I think mine does the same thing. It only drops for a second then the car picks the idle up to where it is suppose to be. I'll look when I drive to work this morning, it might be normal.
Old Apr 3, 2012
GolNat's Avatar
Prelude Owner
My was doing that but it stopped after I cleaned the IAC. Have you done a tune up? Cleaned the air filter? Fuel filter?
Old Apr 3, 2012
ajbias490's Avatar
jdm lifestyle
No not recently. Ill do all that soon. I was gonna do a tune up and stuff soon but didn't know that could be the idle problem. Thanks
Old May 18, 2012
kyle_l88's Avatar
kyle_l88 will become famous soon enoughkyle_l88 will become famous soon enough
I am going to help you out here and hopefully it will solve your issues too. Backstory for me is that I had the same symptoms on my 2000. I changed the fuel filter, cleaned IACV, new air filter, spark plugs, new exhaust manifold (it was cracked), etc. etc. LOL
What you should try next is getting a bottle of Throttle body cleaner and a clean cotton rag and spray the inside of your throttle body where the "butterfly" clip is that opens when you open the throttle. For me the whole edge around the butterfly clip was dirty and caused it to stick sometimes. Even so it wasnt allowing enough air to pass through during idle so when the car came to a stop it expected more air coming in therefore stifling the idle speed until it could correct itself. So my advice to you is. Spend 8$ on that bottle of TB cleaner and try to make that whole inside of the throttle body as clean as possible. Solved my issue, hope it solves yours.
Xuhme
21
Aug 7, 2023 03:40 PM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
beneditti
Jan 15, 2016 12:31 PM
tylerginevan
Apr 27, 2015 12:29 PM
vtechcivic
Apr 21, 2015 06:58 PM
