04 em2 5 speed transmission problem
Old Mar 6, 2012
lovin the ej1's Avatar
lovin the ej1 is an unknown quantity at this point
hey everyone i have a 2004 honda civic, started making a slight chattering noise about 10k ago alot worse now. you push in the clutch it stops, seeems like its always their threw 1st 2nd & 3rd the more you get into it the louder it gets, then when you let off of it the car kinda of rocks back & forwads like its grabing, then it's not, then it is. you can start out in a gear get to a certian rmp and it gets really loud & sounds like it jumped out of gear. gets really annoying after awhile replaced the clutch already. could it be the imput shaft bearing?. woundering if anyone has had the same problem or could give me some ideas. thanks everyone for reading.
Old Mar 6, 2012
GolNat's Avatar
Prelude Owner
Re: 04 em2 5 speed transmission problem
Could be the throw out bearing.
Old Mar 6, 2012
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Sounds like a bad input-shaft bearing to me. A bad throw out bearing would make noise with the clutch disengaged (pedal in).
Old Mar 7, 2012
thanks from what iv been hearing seems like thats what my problem is. in a couple weeks im going to pull my transmission and open her up and see whats going on inside, i gladly will keep everyone posted on what solves this problem.
elitezdc5
May 26, 2015 05:46 PM
cruisers10
May 12, 2015 10:46 PM
jakeconnor
May 5, 2015 07:30 AM
dragonsblood
Apr 27, 2015 12:28 PM
dooner24
Apr 14, 2015 07:51 PM
