car shuts off when the motor heats up
Old Feb 11, 2012
lengo's Avatar
lengo is an unknown quantity at this point
Post car shuts off when the motor heats up
first of all my car does not turn on unless you step on gas but only if the motor is heated up... and when the car idle under 1000 rpm it shuts off unless i keep step on gas.. i got my car check up and they say it was the E.L.D.. i replace that part and it still act the same.. so the thing is that do i have to reset the ecu for the car to run normally... i really need help on this one cause my car been sitting for a month...
Old Feb 12, 2012
toucansam333's Avatar
toucansam333 is an unknown quantity at this point
Re: car shuts off when the motor heats up
Have any codes/check engine light on? Have you checked the Idle Air Control valve for carbon buildup?
Old Feb 12, 2012
lengo's Avatar
no codes have come up ever since i change the ELD.. i havent check that... i take a look at it
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
cooldan1
Apr 23, 2015 10:49 AM
CascadiaBlue
Apr 18, 2015 09:13 AM
