Axle Keeps Popping Out
Old Jan 6, 2012
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Twice I look at my cars passenger side axle and it's popped out of place (on the tranny side) I have no idea why it's doing this
Old Jan 6, 2012
Re: Axle Keeps Popping Out
COOL STORY BRO!
Oh. Did you want some guesses?
Wrong length axle
Snap ring damaged or missing or wrong size or.....sheared the end off at the snap ring groove? Seen THAT happen when one popped out. Not pretty.
Body/frame damage, drivetrain or suspension shifted to one side
Have you pulled the axle all the way out of the trans to look at the snap ring?
Keep the trans full of fluid.
Old Jan 6, 2012
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Sometimes when you remove the axle you weaken the set-ring that holds it in the trans, some people say to change the ring every time you pull the axle out, I'd start with this. If they are original axles I'd get a new set ring from Honda, shouldn't be more than a few bucks.
Old Jan 6, 2012
SlimRisk's Avatar
Busy Speeding!!
Looks like its the stock axles so I do t think it'll be the wrong size. Snap ring sounds like it could be the culprit. I just filled it with new tranny fluid ugghhh. Amsoil isn't cheap
Old Jan 6, 2012
Easy way to tell is to jack both wheels off the ground, remove both axle nuts. Push each stub inward until they stop. Each side should push in roughly the same amount. Probably about 3/4 inch. If one side pushes in a whole bunch farther than the other, that's a problem.
Honda says you are supposed to replace the ring every time the axle is removed. (I almost never do, but hey, if it is a problem, you better try it. It might be a dirt cheap fix.)
10w30 is cheap.
Honda MTF can be had for like $6/qt. on the net. About $8/qt. at the dealer.
Old Jan 7, 2012
04 Honda Civic's Avatar
Loose axle nut? Did you or someone else recently service the axles? Axel nuts get tighter then you think.
Old Jan 7, 2012
lazlong's Avatar
Try $12.99 at my local dealer
Old Jan 7, 2012
MindBomber's Avatar
Live for the Twisties
Then drain the fluid into a clean pan, cover it up, deal with the axle dilemma, re-use the Amsoil. Removing the fluid from the transmission for twenty minutes doesn't decrease it's effectiveness.
Old Jan 7, 2012
SlimRisk's Avatar
Busy Speeding!!
In my ownership the axles have never come out of the car. I did have some wheel stud problem in which the axle nut needed to be taken out, but I'm sure they are torqued right.
Old Jan 7, 2012
MSRP is $7.70 USD right now.
BUT dealers are free to set their own prices.
Why would the kid be draining the trans to change an axle? I sure don't.
Pop the axle out,
put it back in,
top off what dribbled out,
clean it off.
Old Jan 7, 2012
SlimRisk's Avatar
Busy Speeding!!
I'm heading to a concert right so I'll look at the axle tomorrow
Old Mar 5, 2012
SlimRisk's Avatar
Busy Speeding!!
alright i FINALLY got around to looking at my axle, because I havent been driving my car much. It doesnt have a snap ring on it, and I need this car back together and drivable by wednesday night. I really dont want to order from the dealer, what size do I need? and is it just a C-Ring?
Old Mar 5, 2012
My reply from earlier:
https://www.civicforums.com/forums/3...ml#post4582063
Factory axle; use a factory snap ring.
You said somewhere back there that the axles have never been out of the car.....If yours is MISSING, where the **** did it go?
You haven't touched the car in 2 months, and NOW you think you need it by the day after tomorrow?
Old Mar 5, 2012
FordSlayer's Avatar
Gangsta Sexy
FordSlayer is an unknown quantity at this point
Go to napa. Tell them what you need. They should have a book that tells them what one is right, and an assortment. Shouldnt be more then a few bucks. I could get one here for $1.23
Old Mar 5, 2012
SlimRisk's Avatar
Busy Speeding!!
well its not really missing... lemme upload a picture to show you
It looks like a cydrical ring with a small portion, about half an inch, missing (normal) however, thats all it consists of. it doesnt look like a c-ring and I dont think its normal
Old Mar 6, 2012
FordSlayer's Avatar
Gangsta Sexy
Thats the way it is supposed to be. Your ring could just be weak, or the the groove it snaps into could be full of junk.
Old Mar 6, 2012
Thats normal..replace it see if it gets better.
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
bashea
Sep 15, 2015 04:59 AM
JJ291
Sep 2, 2015 11:49 PM
