P0135 code '05 Civic LX
Old Dec 29, 2011
lgs 98dx's Avatar
lgs 98dx is an unknown quantity at this point
Daughter's '05 Civic LX with 80,000 miles just threw P0135 code
my code reader shows:
O2 heater circuit, bank 1 sensor 1
I erased the code, but less than 1 minute after startup the check engine light came on again. Same P0135 code generated.
Tried disconnecting the battery to reset ECM but still throws same code
Factory Honda service manual goes on & on with electrical resistance tests
but doesn't appear to refer to the O2 sensors when diagnosis a P0135 code
However, I saw where there were other posts regarding replacing the O2 sensor(s) when a P0135 code was the issue
Looks like there are at least 2 O2 sensors:
1 just after the exhaust manifold
1 below the engine in the exhaust pipe
If it is one or both of the O2 sensors need replaced, then do I need to buy OEM honda part?
Thanks for the advice
Lg
Old Dec 29, 2011
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: P0135 code '05 Civic LX
p0135.doc
This is the Trouble shooting steps for a 2001, but they should all be the same...
If you can't read it or open it, let me know...This is the first time I have done this...
Old Dec 29, 2011
lgs 98dx's Avatar
Originally Posted by SpdySylvrEX
Attachment 82284
Document opened fine
I will go through the trouble shooting sequence listed and see what happens
Also, I did go to Honda this afternoon and tech said it is most likely #1 O2 sensor (top one), as they replace this item frequently on this engine. Although, occasionally there is an issue with a cracked exhaust manifold (already experienced that on my '98 Civic quite awhile back).
Thanks
Old Dec 29, 2011
yeah, that's your primary one. The one in the CaT is secondary. I believe they are supposed to be replaced every 60,000 miles (don't quote me tho)
If it is cracked you would know by a crappy sounding exhaust...you would know it when you hear it, it's a pretty distinct sound.
Old Dec 31, 2011
lgs 98dx's Avatar
Installed OEM Honda O2 sensor #1 this morning and all appears to be good
Thanks for the help
rcolosi
Apr 29, 2015 07:48 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
civicPesek
Nov 7, 2001 11:33 PM
