P1361 TDC sensor
P1361 TDC sensor
Last night I put a new camshaft (TDC) sensor in. I also unplugged the battery for a half hour to clear the code. On the way to work this morning I got the P1361 code. Does disconnecting the battery for an extended period successfully clear the code?
Why would I get a P1361 error if I just put a new OEM sensor in?
Other issues that may or my not affect this issue.
-Exhaust leak between front pipe and header down pipe. My car sounds like a lawnmower now.(picking up a new gasket and hardware on the way home)
-Threw P1457 error last week, put a new evap valve in, got P1361 the next day so I don't know if this is resolved yet.
Thanks for the help!
-Markus
-Markus
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Re: P1361 TDC sensor
Make sure it is not loose, what year is your car? engine? any modifications?
Disconnecting works, but you can also just pull the fuse under the hood for a few minutes too..think it back up fuse #47 or something like that.
Well not sure if this applies or not.. link incase pic is to small.. http://www.justanswer.com/honda/289w...installed.html
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
