View Poll Results: How common is this problem with Civics?
Drivers with the same problem
0%
This is a known problem with Hondas
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Manual Transmission stick shifter problem
Old Dec 10, 2011
7beauties's Avatar
7beauties is an unknown quantity at this point
Recently the shifter of my manual 2001 Honda Civic EX has become stiffer and the shift doesn't feel definite when I change from 1st gear to 2nd gear and also when I'm shifting to 5th gear. Sometimes the shift doesn't work and I have to go into neutral and try again. What can this be? Is something going wrong with any linkage? And if so, is this common with Honda manual shifters? About how expensive would it be to correct it? I would be grateful for any insight. Thank you.
Sincerely,
7beauties
Old Dec 10, 2011
Re: Manual Transmission stick shifter problem
2 things come to mind:
I seem to remember those having a problem with the pivot, under the shifter lever.
The pivot is like a large plastic ball that the shifter is mounted in, and it splits in half. When it does, it tries to expand when you yank on the shifter. As it expands, it binds and makes it tough to move the lever back and forth.
You would have to buy the whole shifter housing to get it. Almost $50 at Majestic.
The other thing would be where the cables attach to the trans, the round ends could be corroded and seized to the posts of the shift levers. I haven't seen this on the Civics yet though, but I see it on other Hondas sort of often.
For nearly 10x the price of the replacement shift housing, you could get this cool looking thing...
https://www.civicforums.com/forums/2...-7th-gens.html
Old Dec 12, 2011
7beauties's Avatar
Ezone, TY.
Old Dec 12, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
EZ nice pic...that about covers it..
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
cruisers10
May 12, 2015 10:46 PM
pazzmore
Dec 24, 2001 07:39 PM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
