Why HG damage cause engine misfire?
Old Dec 7, 2011
rpca's Avatar
rpca is an unknown quantity at this point
My civic is having intermittent hesitation and misfire on all four cylinders for the past couple months. I took the car to the dealer and they performed chemical test and found hydrocarbon which indicates HG damage. How would HG damage cause misfire and hesitation? The dealer is asking for $1500 to fix the problem.
Old Dec 7, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
Re: Why HG damage cause engine misfire?
because if ur headgasket is blown the engine cant build compression. causing a misfire or very low compression.
if u want it done cheaper take it to a local shop instead. or diy, there is a couple diys for headgasket changes.
Old Dec 7, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Yes as mentioned above HG damage can cause misfire issues. The cylinder loses air/fuel mixture before it is ignited due to loss of compression.
Do you have any loss of coolant or overheating?
Old Dec 7, 2011
04 Honda Civic's Avatar
Small amounts of coolants gets into the cyclinder causing the misfire. Thats why in the morning you will have the biggest misfires because the coolant pools itself up in the cylinder. $1500 is high even for a dealer. I paid $1200 for it to get done at at dealer a few years back.
Old Dec 7, 2011
when you shut the car off, the gasket shrinks and coolant can collect in one or more cylinders. next time you start the car cold, and there is coolant in there and possibly on the spark plug, it will misfire for a minute until it is burned off and everything expands enough to seal the leak. this is why you also start losing coolant from the overflow tank over time with no visible leak (it is burned in the engine) and why there will always be air bubbles when you try to bleed the cooling system.
Old Dec 7, 2011
rpca's Avatar
The car was overheated once about four months ago. It doesn't seem like I am loosing coolant (overflow tank still stay at max) and the temperature looks normal. The strange thing is the misfire/hesitation kind of come and go. It may last for 60 miles and go away and the car will run fine for a while. Then the whole cycle starts again. Do you think it could be some other issues beside damaged HG?
Old Dec 7, 2011
Gunner's Avatar
Are you throwing any codes?
misfires can be caused by vacum leaks in the intake manifold, or behind the throttle body allowing unmetered air to bypass the air flow sensor. EGR valves can be another cause of misfires..It can be anything related to fuel and spark really...
Old Dec 7, 2011
rpca's Avatar
I don't remember the exact codes. I need to look it up when I go back home tonight. But I think they all say misfire on cylinder #1, #2, #3, and #4.
I have two additional questions. The overheat incident happened fairly briefly. It occurred right after I pulled my car to a parking and was about to turn off the engine. I started the car again after 2 hours and everything was back to normal. Do you think the head is still in good shape and not need a replacement?
My car has 105K miles on it. Is it still worth the money to fix the HG and the head (worst case scenario)?
I am trying to make a decision whether to fix it or trade my car.
Old Dec 7, 2011
a slow/small head gasket leak can cause misfires. so can bad or wrong brand spark plugs (ngk and denso are best), clogged fuel infectors, and possibly the fuel pump and/or strainer if it is getting old.
Old Dec 8, 2011
Gunner's Avatar
Misfire on all 4 cylinders is a little less random.. I would check your plugs and wires too and make sure they are all good. Start with the less expensive stuff first and work your way to the head..
Old Dec 8, 2011
drmcstford's Avatar
Civ ILL
drmcstford is an unknown quantity at this point
Hey bud I had the same issue minus the over heating check your spark plugs mines were autolites I switched them to denso problem fixed !!
Old Dec 8, 2011
rpca's Avatar
I got all four plugs and coil packs replaced 2 months ago. I used NGK plugs. Would a blown HG affect all cylinders? I mean all four cylinders will get misfired
Old Dec 8, 2011
pwnsauce's Avatar
a blown headgasket CAN affect all 4...but i wouldnt think it would be likely they would all missfire out of nowhere. unless this problem started right after it overheated. then you probably blew the gasket...or...dare i say warped the head
hopefully not tho but id check ur egr valve vaccum lines and everything they said ^^ first. but my guess it u f***ed up ur gasket or head when it overheated.
Old Dec 8, 2011
when only one cylinder was missing, i got two codes "cylinder 1 misfire" and "random cylinder misfire" even tho i knew it was only one cylinder causing the problem. if you lose more than one, the car will barely even stay running and feel like a big earthquake.
Old Dec 8, 2011
rpca's Avatar
The hesitation/misfires happened few weeks after the car was overheated. I know I need to replace the HG. But what is the chance that the head will still be ok given the overheat occurred right after I parked my car?
Old Dec 8, 2011
pwnsauce's Avatar
the only way to tell if the head is damaged is to pull it off and inspect it.
Old Dec 8, 2011
if it did overheat and you turned the engine off, it will still be hot.
if it did overheat, the last thing you want to do is to not to check head before installing new gasket, you might need to do all the work again. unwise.
if you got hidrocarbon test positive, there is no thinking twice. DO the HG job.
if you have misfire, you will need to come clear on that also before even thinking on trading the car - they will find out in no time.
not even sure why ye so undecided...
Old Dec 8, 2011
you need to take the head to a machine shop to have it checked out. only they will know if it can be fixed up and installed, or if you need another head. the block almost never warps.
Old Dec 9, 2011
Does the car still currently overheat?
Old Dec 9, 2011
rpca's Avatar
No more overheat since that time. Temperature pretty much stay at midpoint during driving.
Old Dec 9, 2011
cja3455's Avatar
cja3455 is an unknown quantity at this point
You may find these youtube videos useful
http://www.youtube.com/watch?v=QA7KV...feature=relmfu
http://www.youtube.com/watch?v=3suQy44G_B0
The combustion leak tester and fluid rent for free at autozone with a deposit. If the test is positive, then you can be sure that there is a combustion leak inside the engine.
Old Dec 10, 2011
I dont believe you have a headgasket problem. What lead you to believe it was the headgasket, the misfire? Is your heat hot? Forgive me I didnt read through the whole thread, however two things you should do is a pull the plugs and a combustion test as mentioned above wouldnt be a bad idea.
Old Dec 10, 2011
rpca's Avatar
Dealear found hydrocarbon in the system. I also took the car to my mechanic and he performed a test similar like the vid shown. Test is positive and hg is blown. I will get it replaced next week.
BTW, is Steel Seal real works? It sounds too good to be true.
thana
Jun 15, 2020 07:05 PM
mikemc422
Aug 9, 2018 05:41 PM
danace99
23
Jun 28, 2015 08:49 AM
zaboomafoozarg
May 30, 2015 09:21 AM
davidarenberg
May 16, 2015 08:45 AM
