Whining Noise When Accelerating and in Neutral
Old Nov 26, 2011
jonnyl888's Avatar
jonnyl888 is an unknown quantity at this point
Hi
I just bought a 2004 Honda civic 1.6 sport as my first car but beginning to think should have done further testing before buying. When I took it for a test drive I could hear a whining noise when accelerating, the owner said it was the sound of the vtec, which I believed.
After buying it and takin it home I realised that accelerating hard have a really loud whine. Also when it's in neutral with clutch disengaged thered is a grinding noise, which goes away when I press clutch down.
I've searched the Internet and have found some people hav had similar problems. And concluded with the input shaft bearing. Will this problem lead to any serious consequences if I keep driving it? And how hard is it to replace the bearing myself? I haven't had any mechanical experience before.
Thanks
Old Nov 27, 2011
lazlong's Avatar
Re: Whining Noise When Accelerating and in Neutral
I've had it for 4 years now. That being said, it will go bad eventually. With no mechanical experience I would leave it to the professionals. Since they pretty much have to take the whole thing apart to fix the bearing you might as well have the whole thing rebuilt. You're looking at $1200-1500 minimum to repair, sorry.
Old Nov 27, 2011
E®ik's Avatar
E®ik will become famous soon enoughE®ik will become famous soon enough
Wow, 2004 1.6? The 7thgen civics are 1.7L engines. and IIRC, the sport does not have vtec. I wouldn't know what the issue is, but it doesn't sound like it could be good. I would bring it to a reputable garage, and have them take a look at it.
Old Nov 27, 2011
jonnyl888's Avatar
I'm not sure what gen it is and whether it's the same in Uk and US. It's the ep2 hatchback model, not sedan. A friend told me it would only cost about £150 labour, I don't want to replace the whole transmission, the bearing itself is about £20 from Honda.
Old Nov 28, 2011
if it really is a 1.6L, the vtec does have a noticable whine to it at certain rpms. if its really loud tho it could be trans or timing belt tensioner related.
Old Nov 28, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Yeah the parts are cheap, there is a lot of work involved though. Prob should have the clutch done too unless its newish. The transmission will have to be pulled and taken apart to replace the bearing.
Old Nov 30, 2011
04 Honda Civic's Avatar
Input shaft bearing. I have the same problem on my S2000. I wouldnt worry to much about it unless it gets really loud. When its time to do the clutch make sure you change it as it wont cost much more to do at that point in time.
Old Dec 1, 2011
anibis's Avatar
Yeah mine has been making noise for about 12k miles now and I'm not too worried, it's still at the point where it's barely noticeable.
I do plan on fixing it when I have to replace my clutch.
If it is very loud or a grinding noise I would be weary.
Old Jan 7, 2012
jonnyl888's Avatar
I just spent the last 3 days taking it apart, but I don't know how to get to the bearing. I hope someone has an idea. I'e read many guides and they tell you to remove a bolt to life out the shift forks and the gear sets but there is no bolt on mine. The shift forks seem to just go into the case??? Please help!!!
Old Jan 7, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
I've never been inside this transmission but I will say this.
#1 You need a Factory Service Manual!!! If you don't have one.
#2 If you proceed farther you need to label and bag all fasteners that you remove and take plenty of pictures!
I speak only from my experiences rebuilding a some manual transmissions.
Nathan
Old Jan 7, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
For someone who doesn't have any mechanical experience, you definitely went to far....GET A SERVICE MANUAL...CHILTON, HAYNES, whatever you have over there...DON'T LET THOSE GEARS GET ANY DIRT ON THEM!!! SMH
Old Jan 7, 2012
jonnyl888's Avatar
I've been using haynes but that don't talk about the transmission, I've got a few questions:
1) What happens if I get dirt in it?
2) What if I accidentally move the synchros around?
3) Will the gears fall out if I pick up the shafts.
4) Any other tips for when disassembling or reassembling the transmission?
Please sound supportive as I'm on the edge of giving up at the moment and buying a new gearbox which I don't have money for. Spent 3 long days of hard labour to take apart the front of the car, I don't really want to stop what I have started...
Thanks
Old Jan 7, 2012
anibis's Avatar
http://www.d-series.org/forums/trans...ng-change.html
http://www.7thgenhonda.com/forum/arc...p/t-12601.html
Old Jan 7, 2012
jonnyl888's Avatar
Wow thanks man the second guide is the exact same gearbox as mine, you saved my life. I'll have to buy you a drink some day.
Also, they suggest cleaning the trans with a solvent. Is white spirit ok?
Old Jan 8, 2012
Biscuit's Avatar
2001 Civic LX Sedan
Is "white spirit" kerosene? If it is then no. Do not clean it with kerosene. Clean it with brake parts cleaner in the aerosol cans. Use the flammable stuff because it cleans better and leaves zero residue.
Nathan
Old Jan 8, 2012
jonnyl888's Avatar
Haven't got any brake cleaner with me, how about wd40 then wipe away? It's mainly the enclosure area so I can apply new liquid gasket sealant.
Also I'm not sure if I bought a good gearbox oil, I called up Honda and they said I need any EP90 oil, and I looked online and saw that EP80W/90 is also suitable. So I bought that but its a mineral version, are there any disadvantages to using mineral rather than synthetic?
Old Jan 9, 2012
Biscuit's Avatar
2001 Civic LX Sedan
WD-40 will not work for a surface that needs to be sealed. The residue that it left behind will cause a leak. Use brake parts cleaner.
The EP80W/90 is the last thing you want to use in your tranny!!!
It's WAY TOO thick!!! Return it and buy 2 quarts of Honda MTF.
Nathan
Old Jan 10, 2012
jonnyl888's Avatar
Thanks, I'm still waiting for some parts, sheared a bolt...
Should I be worried about little bits of dust on the gears? Can I just spray the gears with the brake cleaner and wipe it down?
I decided to return that cheap stuff and get Honda MTF 3.
Old Jan 10, 2012
lazlong's Avatar
If you have to soak the whole damn thing in brake cleaner you can.
Old Apr 14, 2016
Phillip Plypots's Avatar
Phillip Plypots is an unknown quantity at this point
jonnyl888 Could you please give a follow up, how are things after you replaced the ISB? Also, I believe you stated in another thread that the ISB doesn't make noise anymore but now you have a knocking noise. What's going on now with your civic because I'm about to fix the ISB myself with videos from Youtube and DIY's
Old Apr 14, 2016
mikey1's Avatar
dude, this thread is over 4 years old,
you would be better off creating your own thread
15EXCoupe
Jul 30, 2015 12:59 PM
Dani1993
Jul 24, 2015 09:02 AM
wootah88
Jul 21, 2015 10:22 AM
Yazan93
Jul 14, 2015 08:56 PM
06Si_Girl
Jul 12, 2015 12:08 PM
