P0505 cause a P1129
Old Nov 22, 2011
wildcard007's Avatar
wildcard007 is an unknown quantity at this point
P0505 cause a P1129
I have a 2001 Honda Civic EX 5MT
Just replaced the Cat and TDC Sensor yesterday
The Head was reman in July
It now has a rough idle coming out of the repair shop to the point it would sometimes stall out
P1129 is the CEL coming up which is MAP is higher then expected
but i know that the IAC is dirty or going bad i have had a P0505 in the past but its not there currently
Old Nov 23, 2011
lazlong's Avatar
Re: P0505 cause a P1129
With the car at operating temp and idling use the scan tool to see what the sensor is putting out.
Is it putting out 1.1V?
If not, replace the sensor.
Old Nov 23, 2011
Thanks i'll try it out
Old Nov 24, 2011
Civic04's Avatar
Civic04 is an unknown quantity at this point
I cant remember if you have to pull the inner crank pulley (timing belt) if thats the case it might be off a few teeth. I had a customer replace his own belt used the tdc sensor as the timing mark rather than the one on the block and it had a rough idle and threw the map code.
Old Nov 24, 2011
Good to know. I had Lentz replace the TDC when they were welding the cat. just because they have a lift and **** to make the job easy. so it will be something to look at, but hopefully they did it right.
Schmors
Mar 9, 2015 09:14 PM
xRiCeBoYx
Dec 10, 2014 09:07 PM
dogbert
Jun 18, 2013 06:05 PM
Storm897
40
May 17, 2011 09:44 PM
BoneStOck_176
Dec 13, 2009 01:43 PM
