spark plug questions
Old Nov 14, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
i went to go order new plugs cuz i think mine are still stock ones, but whats the difference between these 3?
stock heat range
1 step cooler
2 steps cooler
http://www.procivic.com/pages-produc...598/index.html
not really worried about gas mileage if one or the other will give a bit more performance over stock
Old Nov 14, 2011
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Re: spark plug questions
The heat range has NADA to do with power or gas mileage. It has to do with plug life mostly. It only has to do with power if you have one fouling out. If you have a mostly stock plug, stock heat range will do fine for you. Pull the plugs and "read" them. If the plugs show that they are burning correctly don't change a thing. Put the same thing back in there. The only reason to change them is if performance mods change it, turbo, racing; ie high rpms for extended times, MAYBE if you change to a different fuel type, ie high octane fuel etc., usually if it comes from the pump it will be fine though. If you are just driving its fine stock....
Old Nov 14, 2011
pwnsauce's Avatar
ohhh okay. i was under the impression they needed changed after xx,xxx miles. but i always use premium gas anyways.
how do i know if something is wrong when i pull the old ones out?
Old Nov 14, 2011
pwnsauce's Avatar
and i drive it pretty hard lol
Old Nov 14, 2011
Not recommending a Haynes manual at all, but on the back of most of them there are pictures of spark plugs to "read" them. Ideally they should be clean and maybe a tad orangish type glaze on the ceramics. Look around on the net for images, sure they are out there....
Old Nov 15, 2011
stick with the stock heat range denso iridium.
thana
Jun 15, 2020 07:05 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Micks2K1
Dec 10, 2001 07:11 PM
