Transmisison Leak question, name that part
Old Oct 31, 2011
beastyben1's Avatar
beastyben1 is an unknown quantity at this point
Oops mod please put in Mechanical...
Had a used transmission put in (less 75K miles) and now a few weeks later get this.
1. Could it be the result an overfill?
2. The leaking area looks like the m/t fill plug. But it doesn't look like the pictures in the DIY.
3. What part is that? Is there a gasket? Can I tighten it down some more?
Thanks!
Old Oct 31, 2011
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Re: Transmisison Leak question, name that part
looks like you could just put a 1/2 drive ratchet in there and tighten it. or just get a new one from majestic and put that in. Looks like a manual, and thats where you fill it. if you take out the plug and put your finger in, you should touch the top of the oil line. If some flows out, its overfilled. filling it isnt too hard
Old Oct 31, 2011
beastyben1's Avatar
That's what I was thinking too. But isn't #14 fill and #9 drain? This diagram shows that part as a Sealing Screw 32mm....
Old Oct 31, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
No that isn't the fill or drain bolt, #14 and #9 are as you found on the diagram.
I'm pretty sure that's the bolt you have to remove in order to get access to the snap ring to pull the trans case apart.
http://www.ozhonda.com/gallery/data/.../3IMG_5007.jpg
That's what it looks like if you remove the bolt. Has the trans been rebuilt recently?
I'd make sure it was tight first. If it is I wouldn't see a problem with removing the bolt and putting some Honda bond on the threads, I'm not 100% sure though, maybe someone else can chime in. It's not a serious leak, nothing to worry about inside the tranny.
I don't think you'll lose any fluid by removing that bolt, it seems higher than the fill bolt.
Old Oct 31, 2011
looks like you just need a new plug bolt. chances are they reused the old one during the rebuild or it got loose and now it doesnt seal properly. maybe the rubber got deformed. try tightening it first.
Old Oct 31, 2011
beastyben1's Avatar
Thank you both for the replies. Looks like I'll tighten it and if that doesn't work I'll order a new one, only $4.50. Thanks anabis for the picture, now I know I can't mess up anything just by removing it.
I took a chance on used, not reman'ed transmission. First one with 63K miles was a dud b/c the reverse wouldn't work probably due to a car accident. Second one under warranty seems to be working fine.
Old Oct 31, 2011
SlimRisk's Avatar
Busy Speeding!!
Well i was way off
Old Oct 31, 2011
beastyben1's Avatar
Went out there tonight. Only had a large breaker bar that was 1/2inch and a 6in extension. Had to removed the tire but I got the Sealing Screw to turn 1/8 of a turn pretty easily. Dried everything up and put down some cardboard to see what tomorrow brings.
Old Nov 1, 2011
beastyben1's Avatar
Woohoo. Went out there this morning and there was no leak, cardboard was dry! Thanks everyone!
Old Nov 1, 2011
anibis's Avatar
I'm glad you got it fixed easily.
It is odd that you would have issues with that bolt being loose, it would seem to me that someone has been inside that trans before. This could be a good thing, maybe it's a recent rebuild and you won't have the ISB issue for another 100k.
Old Nov 1, 2011
beastyben1's Avatar
That's what I'm hoping for! But this was purchased from the junkyard's national system. Maybe the PO had it rebuilt. I spoke too soon, still weeps a bit of oil. I'm going to order a new seal for $5 and use some Ultra Grey I have to finally nip it in the butt...
Old Nov 1, 2011
lazlong's Avatar
Yeah, i used it to fill last time. Went in slow.
Torque spec is 18 ft-lbs. (I know I already posted it on your honda-tech thread but, posted it here for the benefit of the people here)
BTW: No where in the service manual does it say you have to mess with that snap ring to remove the tranny.
Old Nov 1, 2011
anibis's Avatar
Yeah I wasn't saying to remove the tranny, I was talking about splitting the case....
Old Nov 1, 2011
beastyben1's Avatar
Thanks for the torque spec, I was curious about that.
Old Nov 1, 2011
lazlong's Avatar
Ah, gotcha. Glad my friend manages a tranny shop and I don't have to deal with that.
Old Nov 5, 2011
beastyben1's Avatar
Well I took the front right tire off. Removed the sealing screw. Coated the threads with some Ultra Grey. Put back in at 18 ft-lbs. Looks great and everything went well. Thanks for every ones help!
Bugman1400
May 15, 2015 08:10 PM
BootyDo
May 7, 2015 04:46 PM
green01civic
Apr 29, 2015 01:36 PM
superstanko
Apr 28, 2015 04:38 AM
bsmiley
Apr 27, 2015 01:27 PM
