manual tranmission rebuild difficulty 1 t0 10?
Live for the Twisties
Re: manual tranmission rebuild difficulty 1 t0 10?
Swapping a trans/changing clutch/flywheel - 6/10
Swapping an engine - 7/10
Rebuilding a standard trans - 8/10
Pulling and rebuilding an engine - 9/10
Rebuilding an automatic trans - 10/10
Civic trans is fairly simple Getting it out and back in is about as hard.
Bearings are reasonably priced (from dealer) Synchros are Not.
So if it needs synchros it's clever to buy a wrecker box
Need help I just pulled my tranny apart to change the input shaft bearing and now the gears work but grind real easy and after driveing in rewind for 30 ft she locks up till I pull foward again it all seamed to be fine free shifting before it went back in the car any help would be great
Zugor
Aug 21, 2015 08:36 PM
estes53
Jul 20, 2015 10:43 PM
01, auto, civic, difficulty, dificulty, diy, hard, honda, level, manual, overhaul, rebuild, rebuilding, tranmission, transmission
