Overheating problem
Old Sep 25, 2011
2002 civic lx's Avatar
2002 civic lx is an unknown quantity at this point
Overheating problem
I was driving home the other day after about 70 miles of driving the whole day. it was very hot out as well, 80-90 degrees. i was on my way home and my car overheated all the way to the H. I pulled over and noticed that coolant had sprayed all over my motor. I also noticed that the coolant overflow hose had blew off. the thermostat is about 50,000 miles used, so i purchased a new radiator cap and bled the system, no bubbles and it seemed find. today i was driving about 10 miles and the same the heater stopped blowing hot air and my temp slowly started to rise. i pulled over and the overflow hose blew off again and sprayed coolant all over the motor. the fans are working when i turn the a/c on, there are no bubbles in the radiator when i bled the system. what could be the problem, the car was fine just a week ago and now this happened. the main question i have is, why is the coolant overflow hose blowing off and causing all of the coolant to spray over the motor. thanks...
Old Sep 25, 2011
MindBomber's Avatar
Live for the Twisties
Re: Overheating problem
The cars overheating due to a bad head gasket most likely, that in turn caused the hose to blow off.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
brian257
Jun 4, 2015 08:17 PM
ttharper
May 11, 2015 07:27 PM
