very bizarre car starting problem
Old Sep 24, 2011
mililani's Avatar
mililani is just really nicemililani is just really nicemililani is just really nicemililani is just really nice
hey folks,
I have a 2001 honda civic lx. Today, I get into the car, start the car while simultaneously opening the windows, then the starter motor starts making this weird noise and the car is having a hard time turning over. I back off the ignition, retry, and the starter motor is cranking and making a noise that sounds like the solenoid died halfway and the starter gears are just grinding. After a few seconds of this, the starter motor begins to bog down like the battery is dying. I try a few times, pump some gas, and just keep the ignition turned on. The car slowly turns over and the engine WEAKLY starts. At first, I thought maybe the battery was giving out. But, the windows were rolling down fine without the car started. After a few minutes of warming up, the car was good to go. It has been starting fine ever since and drives ok.
Anyone know what just happened? Should I think about replacing the starter motor?
much thanks for reading!
Old Sep 24, 2011
lazlong's Avatar
Re: very bizarre car starting problem
May not have been getting enough voltage to turn the starter right. The only source of voltage when the alternator isn't turning is the battery. Don't run accessories (windows) when starting the car. May want to have the battery checked anyways.
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
dragonsblood
Apr 27, 2015 12:28 PM
Blaster30
Apr 22, 2015 12:21 PM
McD
Apr 16, 2015 10:46 AM
