02 sensors
Old Aug 11, 2011
skaterboy2214's Avatar
skaterboy2214 is an unknown quantity at this point
02 sensors
My engine light is on because my 02 sensor is bad but I also have no cat either so is the engine light still going to b there or is there a way to trick the sensor into thinking the cat is there?
Old Aug 12, 2011
bryan11's Avatar
bryan11 is an unknown quantity at this point
Re: 02 sensors
On VWs, I read there's a sensor that's looking for a specific resistance value for correct cat operation. If that's the case for a Honda, finding that value and wiring that 'correct' resistance should make the light go away.
Old Aug 19, 2011
ZFreak's Avatar
Honda Crazy
ZFreak is an unknown quantity at this point
Re: 02 sensors
Yes, search ebay for a 02 sensor spacer. They are about $15. All it does is screw into your secondary O2 sensor (the one behind the cat), and then your secondary o2 sensor screws into that spacer. That will get rid of the P0420 check engine light code. If it doesn't reset on its own within a tank of gas, you'll have to reset it with a scanner. (Autozone will do it for free)
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
