2002 Civic ex Sedan Mileage Issue
Old Jul 26, 2011
Rahway09's Avatar
Rahway09 is an unknown quantity at this point
hey guys so i have a 2002 civic ex sedan with 93k miles and i basically fill up on gas weekly only running 250 mpg/ 400kmpg. i dont know whats wrong i change the oil every 3000 miles, changed the spark plugs, air filters, check the air pressure on tires, battery's brand new but yet my gas mileage sucks somebody help please and thanks
Old Nov 23, 2011
Rahway09's Avatar
Re: 2002 Civic ex Sedan Mileage Issue
bump!
Old Nov 23, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
How much fuel is it taking when you fill it up?
The only way to know MPG for sure is to fill it up and reset your tip (or write down mileage), drive it until 1/4 tank, fill it up again at the same pump and same station, write down how much fuel it takes and how many miles you drove. Divide mileage by how many gallons it took. IE 250 miles divided by 11 gallons = 22.2 MPG.
It could be the gauge is being funny. Our tanks hold 13.2 gallons but will rarely take more than 12 when the gas light first comes on.
Old Nov 24, 2011
lazlong's Avatar
That's because there's still 2-3 gallons left when that light comes on. I once had to go 83 miles after the gas light came thus proving there's at least 2 gallons in there when the light comes on.
Old Nov 26, 2011
Rahway09's Avatar
anibis=when i fill up it takes like almost 11 gallons and i reset my trip log every time i fill up so that i know how much more i can run without running out and ok ill do that and let you know how much the mpg is
lazlong=yea i have noticed that the more u drive with the little picture the more gas ull need and i can run for like 40 miles lol
Old Nov 26, 2011
lazlong's Avatar
Accelerate slower, brake longer. Also, these cars shut off the fuel flow over 1200 rpm if you're coasting in gear.
Old Dec 5, 2011
Rahway09's Avatar
Anibis so this is my mpg
Fill up 1(11/24)252 miles and took 9.962g=25 mpg
Fill up 2(12/3)246.6 miles and took 9.787g=25mpg
Old Dec 5, 2011
ubnpast's Avatar
ubnpast is on a distinguished road
Did you try different gas stations, some stations have lower quality gas, I get about 37-39 on my 01 lx with 191k on it (440 miles to a tank)
Old Dec 7, 2011
Rahway09's Avatar
Im gonna start using exxon or sunoco from.now on to see if thats the issue thc
Old Dec 7, 2011
the best is citco, next best is chevron, then exxon/mobil. shell and most of the others are distant last.
Old Dec 7, 2011
Cold weather/cold starts/and warming up the engine, kills gas mileage.
Any time the engine is running and you are not moving, kills gas mileage.
Winter fuel blends get less mileage.
Alcohol/Ethanol fuel gets less mileage.
Low pressure in the tires kills gas mileage. Tire pressure drops when the weather gets cold.
Other car problems can kill gas mileage. (Dragging brakes, runs poorly, check engine light, etc.)
Teenage driving habits kills gas mileage (don't ask). Drive like a grandma.
Read about hypermilers. See how they do it.
Good fuel info: http://www.toptiergas.com/
Old Dec 10, 2011
Rahway09's Avatar
gearbox=ok thanks
ezone=i try to avoid letting it warm up unless theres frost then yea,my tires are good, and everything is good (new battery,new spark plugs, new brakes and etc) and ive tried driving like a grandma lol and it still eats gas
Old Dec 10, 2011
lazlong's Avatar
Try resetting the ECM/PCM then do the idle re-learn. You'll have pretty bad mileage until it gets enough data for a decent fuel trim but, should get better after that.
Also, have you checked it for codes?
Old Dec 10, 2011
25 MPG isn't too far off the mark. As always, your mileage may vary.
http://www.fueleconomy.gov/feg/Power...ic&srchtyp=ymm
Old Dec 10, 2011
MindBomber's Avatar
Live for the Twisties
Check for stored codes, if an 02 sensor is gone then that could account for the lower mileage.
I average 38-40mpg with summer fuel and on winter blends 35-38mpg with a 60/40 mix of highway to city driving. Not driving like a grandma, but also not overly aggressive.
Old Dec 12, 2011
Rahway09's Avatar
Lazlong=ok ill do that relearn and see if it works,
Ezone= I know but everyone gets like 300+ miles per full tank wherr I only get 250 at max
Mindbomber=i cant search for codes cuz I dont have a machine or anything
Old Dec 12, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
is your check engine light on?
Old Dec 12, 2011
PeterLazro's Avatar
2002 Civic LX-G
PeterLazro is an unknown quantity at this point
@mindBomber. Wow thats really good. I get around 8.3L/100km about 28mpg. with 70/30 city/highway. The highest I ever got was 700km to the tank with 95% highway doing about 120km/hr
I remember gearbox said something about changing the primary O2 sensor for better fuel/air ratio. I think mine are running originals at 200K KM. My tires and air filters are always checked.I did my sparks last December along with a tranny fluid change. I don't know you guys get such amazing gas mileage. I drive conservatively and let off the gas way ahead of where i need to stop. The areas of my driving which I kill my gas are on the on ramps to an highway. With no tq you really gotta press down on these civics. I put in a bottle of techron fuel system cleaner that you guys get in the US and I have noticed an improvement in throttle response.Now when i press down, the car actually moves! Not sure about gas mileage. Ill have to see after this tank is done.
Old Dec 12, 2011
anibis's Avatar
Yeah some people say the fuel injection cleaners are junk but they actually do work. The first time I ever used it in my '93 Mustang (bought it used) I got about a 20% bump in MPG, also had a friend get a similar bump in his Toyota Celica. Neither car had never been treated with FI cleaner before.
If you have never used a FI cleaner in the car it may help a great deal.
Old Dec 12, 2011
winter does a number on gas mileage. there are so many variables working against you that a 10mpg drop is pretty normal compared to summer. these cars were not designed to run optimally in cold weather.
Old Dec 12, 2011
04 Honda Civic's Avatar
Easy on the gas, and remove all the **** you dont need in your car. Sounds like you properly maintain the car, so maybe your driving habbit is to blame?
Old Dec 13, 2011
Rahway09's Avatar
Gunner=no the check engine light is not on
Anibis=ill try the fuel injection cleaner see if that works I hope it does
Gearbox=in the summer I have the same issue it doesnt reach 300
04 honda civic=i dont have anythint in my car but my jack,case of water and pillow lol
Old Dec 13, 2011
HondaBeast's Avatar
HondaBeast is an unknown quantity at this point
Pillow? Do i even want to ask..LOL maybe that is the issue, heating your mobile home at night will burn gas kidding.
Old Dec 14, 2011
Rahway09's Avatar
Honda Beast= i work and go to school and some days i have a break in between classes i take a nap in my car thats why i have a snuggie and one of those car pillows lmao
Old Dec 15, 2011
Gunner's Avatar
You gotta do what you gotta do, school and work is a tuff sked..i dont blame you.
Old Dec 23, 2011
Rahway09's Avatar
Gunner=yea i know i get up at 4am for work and i get out of school at 830pm!
Old Jan 6, 2012
Rahway09's Avatar
hey guys so update! i went to baltimore the other and i pretty much almost ran out of gas on the highway so i filled up and ive been filling up at sunoco and quick chek gas stations and now the gas is lasting alot more now. so i guess it was the gas station i was using
Old Jan 9, 2012
Gunner's Avatar
Glad to hear your problem is solved..sux to know some stations gas is subpar quality..
Old Jan 9, 2012
For the OP: Read up
Old Feb 19, 2012
Rahway09's Avatar
hey guys so the problems back ive only been using quik chek and sunoco gas stations and still the gas is getting eaten up like today i filled up and the little gas empty signal was on for a while and i only ran 290 miles in about 9 days. im getting really fed up of spending 40 dollars every week for gas. if this continues i may have to sell this car and get a more fuel efficient one :/ any suggestions as to what else i can do ?
