2001 civic
Old Jun 2, 2011
carreoneast's Avatar
carreoneast is an unknown quantity at this point
2001 civic
have a 2001 civic ex. changed the alternator and battery. battery and srs lights are on. car stalls after driving a bit. abs and alarm lights come on intermittently. am at my wits end. any help would be appreciated!
Old Jun 2, 2011
MindBomber's Avatar
Live for the Twisties
Re: 2001 civic
The srs light is likely unrelated to your issues, it signifies an issue with the airbag system, search arnd you'll find information on how to clear the indicator. If the light is on the airbags will not deploy in an accident.
On the stalling issue, check your ground wire connections.
Old Jun 3, 2011
lazlong's Avatar
Re: 2001 civic
And check for loose connections.
Old Jun 8, 2011
Downhill Demon's Avatar
Downhill Demon is an unknown quantity at this point
Re: 2001 civic
I just had very similar problems. srs light, abs light on and some stalling. I manually read my codes and got a code 61 (ignition voltage). Get your alternator checked. My alternator was charging at 16.7 volts. After i changed it, no more warning lights and car ran smooth. After you disconnect your battery make sure you initialize the PCM idle learn procedure. Both abs and srs lights were affected by the high voltage. I'm glad this fixed up the srs. I have already replaced both belts within the last 2 years to the tune of about $900.
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
