For an 01 honda civic codesp0131,p1362,p1361 in that order.Please help!
Old Jun 2, 2011
cavsmets's Avatar
cavsmets is an unknown quantity at this point
I was driving home today and all of a sudden the engine light came on,my car started bucking and I lost power.I drove 50 miles and my car would not do over 20 miles an hour.I started smelling rubber burning and when I came to a light,it would stall.I put a code reader on and the codes came up as follows,1st was a p0131 which said it was an 02 sensor.,2nd was p1362 which was TDC1 sensor no signal and the last one was TDC sensor intermittent interruption.Please tell me if it has to do with the transmission or what ever other problem can cause this.Thanks and by the way,its for a 2001 Honda civic LX
Old Jun 2, 2011
jeremyhurst02's Avatar
Newb
jeremyhurst02 is an unknown quantity at this point
Re: For an 01 honda civic codesp0131,p1362,p1361 in that order.Please help!
the p1362 is referring to your position sensor i beleive, and I got this from a separate thread on a different website after searching your issue:
If that sensor goes, the computer doesnt know where the cam is relative to the crank, so it shuts down to prevent itself from ripping itself apart. Its under the timing cover and under the cam gear on the driver's side of the motor. There's a fair bit of disassembly needed to get it out (the whole timing set), so if the car is anywhere close to 90,000 miles, just do the entire timing belt/water pump job. Its probably also wise while you're in there to change the crank position sensor on the side of the oil pump... that one's also going to eventually crap out.
also saw this reply to the same thread in regards to that issue:
Our 2002 Civic was doing the exact same thing. We have 140k on it. The diagnostics kept coming up with the TDC sensor, so we replaced it. The car worked fine for about 50 miles and then started do that fading out thing. We took it to the dealership and they said that we needed to replace the catylitic converter, and wanted to charge us 1800 bucks. Well we've had plenty of catylitic converters replaced in our life time for under 200 bucks, so we took it somewhere else to have it replaced. Car continued to do the limp thing usually when in 5th gear for a prolonged amount of time. (check engine light came back on) soo we took it to a different honda machanic. It was indeed the catylitic converter, but un-known to us, honda vehicles only want honda parts....and yes, they had to put a honda catylitic converter on (1200 bucks), but they also had to replace the pipe that the other shop had cut to fit the non-honda converter. (another 200 bucks). so in the end we spent 1600 bucks to replace the converter....200 for 1st non-handa converter...1200 for new HONDA converter...200 for pipe. Car runs great now, and I'm sure it will last another 140k miles. HAVE YOUR CATYLICTIC CONVERTER checked out.
Hope this helps.
jessicakaybby
Apr 20, 2015 12:11 PM
