Clutch Growl? 03 LX
Old Feb 11, 2011
Blacksun5084's Avatar
Blacksun5084 is an unknown quantity at this point
Clutch Growl? 03 LX
I have an 03 LX with approx 106k miles that the clutch has been growling for over 4k miles (didn't have money till now to fix) It only makes the noise when the petal is engaged (no foot on it) and it is UN-noticeable when coasting in neutral. It shifts a little rougher than when in the past but it is still very smooth. I have noticed no fluid leaks and the clutch never smells hot. Any help would be awesome!
Old Feb 11, 2011
MelJ's Avatar
Trance Addict
Re: Clutch Growl? 03 LX
Do you mean the car is shaking when the clutch is being engaged? If that's the case, it could be clutch chatter. If it's doing this as you're driving, it could be loose flywheel bolts or worn mounts. That's assuming this growl is shaking. If not, I'm out of ideas.
Old Feb 11, 2011
BobDobolina's Avatar
TRUST me! I'm Idiot Proof!
BobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura aboutBobDobolina has a spectacular aura about
Sounds like an input shaft bearing problem...or something transmission related if it makes the sound only when the clutch is engaged. Does it sound funny when you first start it up and let off the clutch in neutral?
Old Feb 23, 2011
Sorry bout the long over due reply. It is defiantly a growling noise not a shaking and it gets worse as the car warms up. I haven't noticed it making the noise in neutral or if it is its so quiet I don't notice. As weird as it may sound the noise almost sounds like a knocking lifter on a Ford! But I know it is not my engine
Old Feb 23, 2011
Hmmmmm....
Im still trying to figure out if its the clutch, engine or some part of the drive train.
1. When parked, an its in neutral, and you push the clutch in and out...noise?
2. When parked, an its in neutral, and have the clutch out (engaged)...noise?
3. When parked, an its in neutral, and you have the clutch in (disengaged),....noise?
4. While coasting (be careful, and turn off the radio an any fans/noise makers), push the clutch in....noise goes away? comes back with drive train engagement?
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
powman02
Sep 15, 2015 07:38 PM
bashea
Sep 15, 2015 04:59 AM
Klame9420
Sep 7, 2015 10:03 PM
