rear suspension knocking sound
Old Jan 31, 2011
djpat28's Avatar
djpat28 is an unknown quantity at this point
Have a 2003 civic and when the rear right wheel takes a crack or bump on the road it does a knocking sound. I've check the bushing and seems fine it also began doing that noise when it became cold (i live in quebec) So i was wondering if it could be the shock or maybe the damper mounting base.
Need help please!
Old Jan 31, 2011
lazlong's Avatar
Re: rear suspension knocking sound
The cold does funny things to rubber and plastic. Is it 1 knock or like a jittery knock? 1 knock is usually bushing(s) or bad strut, jittery knock is usually the mount.
FYI: If you replace the bushings or strut go ahead and replace the other side too. When you replace one side it puts more pressure on the other side and you end up replacing the other side pretty soon anyways.
Old Feb 1, 2011
djpat28's Avatar
it's 1 knock and it's not rebounding either so can it still be the strut even then?
DVexile
Jul 2, 2021 05:25 PM
edspyhill09
Jun 12, 2016 02:45 PM
reqy
Jun 1, 2015 07:05 AM
Supramk3
May 11, 2015 07:55 PM
supercivic01
South
Nov 30, 2001 11:27 AM
