HELP bad vibration on 2002 civic
Old Jan 5, 2011
floyd107's Avatar
floyd107 is on a distinguished road
Question HELP bad vibration on 2002 civic
i have a 2002 civic lx and i have a pretty bad vibration problem through out the car.bad enough to make everything in the car including the hood to raddle. i just had the motor and trans mounts replaced and the car still vibs at idle around 1k. plz help im out of ideas and i cant pin point this thing. if it were to be a missfire prob what are some other signs i can look for?
Old Jan 5, 2011
Re: HELP bad vibration on 2002 civic
can you describe it better? is it at idle, while the car is moving, what are the rpms, is the engine light on, etc.
Old Jan 5, 2011
floyd107's Avatar
its mainly at idle at about 1k but when in motion the vib is hardly noticeable except you do feel a contstant thud on the gas pedal.
Old Jan 5, 2011
almost sounds like the engine is misfiring, or there is a problem with fuel system. maybe try changing the spark plugs first and see if that helps.
Old Jan 5, 2011
floyd107's Avatar
I'll try that, If that does not work; do you have any other suggestions?
Old Jan 9, 2011
floyd107's Avatar
does anyone have a diffrent idea???
Old Jan 9, 2011
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Check for loose trans and engine mount bolts.
Old Jan 9, 2011
lazlong's Avatar
Yeah, I was gonna say engine mounts. Sometimes if the mounts are bad it makes the knock sensor read weird and causes a misfire condition.
Old Jan 9, 2011
floyd107's Avatar
The vibration started before i changed my all my mounts. The only mount not changed was the rear. But i do have new mounts and the vibration still persists.. Is there anyway to check the rear mount. Its a hard vibration and is noticable even when moving. But the vibration isn't as noticable when moving due to road vibration.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
15
Nov 8, 2001 05:06 PM
