2002 Civic Door Lock - Key Doesn't Turn
Old Jan 5, 2011
noblehouse1841's Avatar
noblehouse1841 is an unknown quantity at this point
The key fits into the lock but then doesn't turn. It first didn't work on the passinger's door then last night the drivers door. The door locks still work using the inside autolock and manually so I assume the machanisms still do their job. The dealers response is to "just bring it in" which costs a fortune. I tried the whole WD-40, etc. route but nothing. I searched the other threats but didn't find anything on point.
Old Jan 5, 2011
Re: 2002 Civic Door Lock - Key Doesn't Turn
yeah its a sign of aging door lock actuator. you need that whole latch piece where all the rods and stuff connect to. around $50 i think and not too hard to change by removing the door panel and swapping the part. i have the same problem but since the keyless still works, i havent bothered to replace it (passenger key still works). i cant lock mine from inside tho cause its very hard to push the lock down.
Old Jan 6, 2011
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
Are you using an original key or or a newly cut key?
Are you are using a newly cut key based on the old key or a new cut key from factory code?
Nathan
Old Jan 8, 2011
These are original factory cut keys that came with the vehicle.
CarStuff
Dec 6, 2020 12:52 PM
roverben
Jan 21, 2019 05:16 PM
civic_gt
Apr 19, 2015 08:15 AM
darwin-t
Apr 18, 2015 09:29 PM
smmahan
Apr 15, 2015 08:17 PM
