Shifting problem
Old Dec 10, 2010
marviselly's Avatar
marviselly is an unknown quantity at this point
Shifting problem
My car just started to shift poorly after second gear. From 1st to 2nd it will shift perfectly. Then afterwards it's ridiculous. It will go all the way to redlining while barely accelerating until you let off the accelerator, after that it will shift up when you re-accelerate. Any tips on what the problem could be and a solution.
The only problem my computer reads with the "check engine" light is "catalytic converter" issue. I'm assuming it's just an 02 censor that's faulty. But I know that wont cause any shifting errors.
Old Dec 10, 2010
MindBomber's Avatar
Live for the Twisties
Re: Shifting problem
I'm assuming its an auto, if its slipping that much it means your transmission is toast. Its a common problem with 01-05 civics, the clutch pack is defective and the fluid filter is poorly designed. The options for repair are a new trans, around $4000; a used trans, but sell the car because it will likely fail; a rebuilt trans, again sell the car; or a manual conversion.
Use the search button, you'll find lots of information on this problem.
Old Dec 11, 2010
BlueEM2's Avatar
Whachya lookin at?
I'm assuming you have a 7th gen, if not let me know. I moved this thread into 7th gen mechanical issues subforum. You might have more luck getting help here.
97-DX-Lover
Jun 14, 2015 06:07 PM
Blazz
Jun 4, 2015 01:04 AM
usajags84
May 30, 2015 06:49 PM
cruisers10
May 12, 2015 10:46 PM
Marcus2thextrem
May 10, 2015 03:08 PM
