more and less power after lubricating clutch slave cylinder
Old Nov 21, 2010
lorolia's Avatar
lorolia is an unknown quantity at this point
Hi,
this is a little bit strange to explain:
I got this squeaky clutch sound under the hood so I removed the slave cylinder and lubricated the joint in the release fork.
When I put things together and drove the car it felt with more power than before (I could easily make tires to screech) so I was more than happy
but days passed and I felt the car went back to its previous condition.
I mean the car was OK and still drives OK but I feel it has lost this quick pick-up it got after I lubricated the joint.
any ideas how to regain this condition permanently ?
thanks in advance.
Old Nov 21, 2010
lazlong's Avatar
Re: more and less power after lubricating clutch slave cylinder
A new slave cylinder.
Old Nov 25, 2010
lorolia's Avatar
thanks, I already did that and the behavior is the same
when I first installed the new slave cylinder I felt the car with more power but after some driving I felt it lost what it has gained before.
could be something related to the release fork? is there any adjusting I can do to it?
Thanks again
Old Nov 28, 2010
lorolia's Avatar
I´ve been thinking maybe I did something wrong at the time of installing the slave cylinder...
can someone outline a procedure how to do this?
this is what I did:
1- unbolted the piece
2-lubricated with red grease (bearing grease) the joint in the release fork and the clutch slave cylinder
3- installed clutch slave cylinder and bleeded it
4-pump the clutch pedal a few dozen of times and that´s it.
can someone tell me if I did something wrong?
thanks
Old Nov 28, 2010
lazlong's Avatar
You still have air in the system. Bleed it again and again and again until there is no air left. I've seen people bleed these 10 times or more sometimes. Wait a little while before each bleed to give the air bubbles time to gather.
Old Nov 28, 2010
lorolia's Avatar
well, thank you very much.
I´ll do it right away!
can you tell me why air bubbles are bad for the system?
and I found this procedure:
https://www.civicforums.com/forums/3...ng-clutch.html
is it the right way to do it?
Quote:
Originally Posted by: solar
"As far as bleeding goes its really simple, have someone sit in the car, make sure the Clutch Master Cylinder is full of fluid. Open the bleeder valve on the Slave and have your friend SLOWLY push the clutch pedal down to the floor. Once the pedal is on the floor,keep it on the floor until you close the bleeder and let the cltuch pedal back up, repeat until all the air is out of the line. Make sure the Master stays full, it shouldn't take but a couple of times before its done."
Old Nov 29, 2010
lazlong's Avatar
A liquid in an enclosed space exerts equal pressure in all directions. It acts like a solid and won't compress. Hence, when you push on the petal it acts as a solid on the other end of the line. Air compresses and won't provide the same amount of force as a solid on the other end.
The bleed procedure is fine.
sysblack
May 13, 2015 08:55 PM
Supramk3
May 11, 2015 07:55 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
bsmiley
Apr 27, 2015 01:27 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
