The tire shop cross threaded my stud!
Found another issue with having people work on the whip! I'm currently switching to my steelies for the winter (easy enough task). I couldn't sleep so I did what any sane person would do and I snuck into the garage to wrench
I loosened my lugs and jacked up the front passenger wheel but noticed when I jacked it up only three of the four could be loosened by hand. Thinking I had forgotten to fully loosen the lugs I reached for my 19mm socket and loosened but it struggled to me removed. I removed the lug but knew that the tire shop had screwed my stud up so I grabbed an extra lug and tried to re-thread the stud but to no avail!
Anyone changed the wheel stud before? I searched and some say I just need to remove the disk and hammer out the stud and replace while others say I have to pull the axle. The parts are pretty cheap and I know this can be done for $5 or less but I just would like to know which method works/works best (easiest preferred).
BTW: 03 EX Coupe Front Passenger Side Wheel Stud
I loosened my lugs and jacked up the front passenger wheel but noticed when I jacked it up only three of the four could be loosened by hand. Thinking I had forgotten to fully loosen the lugs I reached for my 19mm socket and loosened but it struggled to me removed. I removed the lug but knew that the tire shop had screwed my stud up so I grabbed an extra lug and tried to re-thread the stud but to no avail!Anyone changed the wheel stud before? I searched and some say I just need to remove the disk and hammer out the stud and replace while others say I have to pull the axle. The parts are pretty cheap and I know this can be done for $5 or less but I just would like to know which method works/works best (easiest preferred).
Re: The tire shop cross threaded my stud!
Cool man. Just purchased all the parts for the fix.
Wheel Stud $1.99 Autozone
Open End Lug Nut FREE Firestone
2 #12 Washers DONATED Home Depot
Pretty inexpensive fix but I'm curious how long the labor will take. Will post when finished. I'll attempt this after I get off work tomorrow A.M.
Update... pulled off caliper & disc but the hub is a pain! Just picked up a loaner tool (slide hammer) from Autozone which should make the hub submit. Looks like this project is delayed until I get off work tomorrow *grr*
welcome to the club...
Mine were stuck in the stud for a year because the shop did not want to take responsibility... Had another shop drill nut and stud out - took 2 days...
There is a way to no take the hub off. You have to hammer the first one out with the hub on then you grind one side of the new stud flat and it will barely squeeze past the dust cover or whatever is there and go into the hole.
It's kinda hard to describe without showing a pic or something. But I have done it a couple times before.
Really? I was trying to verify this with a DIY I saw and noticed that it's for an 2000 civic! I didn't try and pull the hub off yet but from looking at it I fully agree with you that it doesn't come off (atleast doesn't appear to come off easily). I don't have access to a grinder though! I have a big file but that is all I have. Anyone done this before? I searched the issue and found a DIY but like I said before I just now noticed it's for a 2000. I've replaced studs on other cars before and it was pretty straightforward but this is the first time I'm attempting it on my 03.
Not a bad idea! Wish me luck I'm out to the garage to tackle this beast! I was reading and it says the hub can be removed... tough part is they said it wasn't gonna be easy. LOL
The champ is here...haha! It was a long fought battle but on this day I conquered a beast of an opponent
I took a few pics but not neccessarily a step by step. The key is to have the proper tools. An impact gun helped but with hand tools it's easily possible. The key to hub removal is a slide hammer (autozone loaner tool #27033) & an axle puller (autozone loaner tool #27037). To remove the axle nut you'll need a 32mm socket.
I took a few pics but not neccessarily a step by step. The key is to have the proper tools. An impact gun helped but with hand tools it's easily possible. The key to hub removal is a slide hammer (autozone loaner tool #27033) & an axle puller (autozone loaner tool #27037). To remove the axle nut you'll need a 32mm socket. Re: The tire shop cross threaded my stud!
brake assembly
17mm bolts (x2) holding brake caliper
12mm bolt securing brake line
pic shows stripped wheel stud and hub (note that the axle nut is still in the pic. The nut is 32mm and needs to be removed before you attempt to remove the hub)
slide hammer AZ tool #27033 (right) & axle puller AZ tool #27037 (left)
Last edited by CGaud; Oct 20, 2010 at 04:24 PM. Reason: wtf...unsure about how to post pics right now :(
CGaud-When you used the axle puller, did the hub easily separate from the other parts? It started sliding off the axle but would not separate from the parts that connect to the strut. I thought that the hub would separate from the bearing. Is that what is expected? Am I missing something?
You will start to see it pull away from the axle keep pulling until it fully disconnects. I am also assuming that you have removed the rotor and removed the two phillips head screws attaching the rotor to the hub. Looking back at this post I failed to show those pics. I hope this helps.
Yea I removed the rotor from the hub. Currently I have the hub and the knuckle (attaches the the strut) pulled from the axle. The hub would not separate from the the knuckle and the bearing. Just a little frustrated.
cmart1209
May 29, 2015 04:52 AM
bo_red
Apr 23, 2015 10:09 PM
