p0135 02 heater sensor
Old Sep 29, 2010
raidersjoe's Avatar
raidersjoe is an unknown quantity at this point
I just bought a 2001 civic ex. check eng light was on. hooked up to a obd2 and got code p0135 02 heater sensor. I understand this is the heater element of the 02 sensor. I replaced the 02 sensor yesterday and then unplugged the battery for about 15 minutes. after plugging the battery back in i sterted the civic. no light, but after about 15 or 20 seconds the check eng light is back on. any suggestions? is there a relay? can i test the circuit at any specific location? is there a fuse? I have decent mechanical abilities, but I have never done electrical work...
Old Nov 27, 2010
2000.civic.ex's Avatar
2000.civic.ex is an unknown quantity at this point
Re: p0135 02 heater sensor
I too am having this issue. I have a 2000 HONDA Civic EX 2dr 4spd automatic. I bought a Bosche Sensor and had no luck. I bought a DENSO one and still no luck. I've read alot of forums and now know its not the actual sensor's. Im clueless on what to do or look for now. I also checked all my fuses and they're all fine.
Old Nov 27, 2010
lazlong's Avatar
There's an open somewhere in the circuit. You're gonna have to test wires between the sensor and PCM. Download or get a service manual and it will tell you exactly how to find the open in that circuit. I don't have a manual for 6th gens or I'd email it to ya.
Old Nov 27, 2010
What exactly is the PCM, and how is it done?
Old Nov 27, 2010
lazlong's Avatar
"Download or get a service manual and it will tell you exactly how to find the open in that circuit."
I don't have a 6th gen manual meaning I have no schematics meaning there is no way I would know which wire is which. You need schematics from the manual and a multimeter to check this out.
A PCM (Powertrain Control Module) controls the running of the engine, it's like the brain of the car.
Old Nov 27, 2010
Thanks for the help.
I found this.
http://files.clubcivicquebec.com/Man...ice_Manual.pdf
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
EliseKStewart
Jul 15, 2015 11:11 AM
mistermenphis22
Jul 13, 2015 04:43 PM
