Car keeps overheating
Old Sep 27, 2010
onone's Avatar
onone is an unknown quantity at this point
I have a 2002 Honda Civic DX. It's been overheating on me whenever it is 85+ degrees outside. When the car overheats, the left fan doesn't turn on bu the right one does (looking from the front of the car and into the hood).
Before I do anything to fix the problem, it is the radiator fan that is messed up, right? If so, can you provide me instructions on how to change it. Thank you.
Old Sep 27, 2010
02civicsi02's Avatar
Low and slow!
Re: Car keeps overheating
The left fan looking in from the hood is the radiator fan and if it doesnt come on then that is your problem.
Old Sep 27, 2010
onone's Avatar
Ya, figures...i was hoping it was just a bad radiator cap. Any instructions on how to change out the fan?
Old Sep 28, 2010
lazlong's Avatar
No, that COULD be your problem. Test the fan, if it works then it's the fuses (#4 in the under-hood fuse/relay box and #14 in the under-dash fuse/relay box), or relay (in the under-hood fuse/relay box), or the switch (in the thermostat housing).
Old Sep 28, 2010
lazlong's Avatar
If you need a new fan motor. Best bet is to buy the assembly from the salvage yard for like $50. Just the motor alone at Honda is almost $200. http://www.car-part.com/
1) disconnect neg batt cable. 2) disconnect upper radiator hose @ the radiator. 3) remove body pins from top of grille. 4) GENTLY, as not to rip grille from bumper cover, pull grille forward and remove the 2 bolts holding top of radiator assembly. 5) push assembly rearward and remove the 1 bolt holding the overflow bottle and the 2 bolts holding the fan assembly. 6) remove old, install new, reassemble. Takes like 10-15 minutes
Old Oct 4, 2010
onone's Avatar
thank you all. it was the fan that was messed up. i changed it out with a new fan that i got for $45! the process of replacing it was pretty easy.
Xuhme
21
Aug 7, 2023 03:40 PM
ChristinaVHH
May 10, 2015 03:51 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
