Plzzzzzzzzzzz help
Old Sep 7, 2010
maximus81's Avatar
maximus81 is an unknown quantity at this point
Unhappy Plzzzzzzzzzzz help
Hi
i really need ur help
I have a civic EXI 2003 model, I noticed that the coolant level is getting lower day by day
then as advised by my the garage I used to deal with to change the gasket and then every thing was fine for almost 3 days.
THE MAIN PROBLEM NOW IS THE CAR RUNS LIKE HELL (WHEN IT'S COLD) BUT AS SOON AS I STOP FOR ANY REASON SUCH AS TRAAFIC LIGHTS ,,THERE IS NO POWER AT ALL ,THE CAR WILL NOT ACCELERATE ANY MORE ...I WOULD HAVE TO HIT THE PEDAL 3-4 TIMES TO START MOVING ANT IT TAKES AGES TO MOVE.(AND THIS IS ONLY HAPPENS WHEN THE ENGINE IS HOT , AFTER A LONG RUN )
I CHANGED THE AIR FILTER-THE PETROL FILTER-THE SPARKING PLUGS...BUT NO USE AT ALL
PLEASE HELP
Old Sep 7, 2010
Re: Plzzzzzzzzzzz help
if its burning coolant and no leaks, its the headgasket. can also explain the poor acceleration cause you prolly have coolant all over the spark plugs. pull one out and look for white residues. could also have contaminated the oil. check oil too and see if it looks milky. if any of these things are visible, get it fixed asap or you risk blowing the motor.
pipquick
Apr 4, 2011 03:24 PM
