P0420 code with some history
Old Aug 30, 2010
brians02ex's Avatar
brians02ex is an unknown quantity at this point
Hi everyone, new here so sorry if I dont include important information...
A month ago I had my check engine light come on so I went down to my local autozone and spoke with someone there and had the codes pulled. It was p0420, autozone lists some probable causes with their code reader and speaking with the autozone people and some friends the assumption was that as the car should have the o2 sensors replaced (130k miles now) we should start with that.
Since replacing the upstream and down stream o2 sensors the cars performance is inarguably better, but after a day of the check engine light being off now its back on. From a lack of car savvy, i decided to reset my battery again and see if the light comes back, which it did. I took it back to Autozone and it came out with the same code p0420: catalsy system efficiency below threshold bank 1.
probable causes: a/f ratio, air leak near h02s (heated oxygen sensor) bank1, ignition system concern & faulty cat converter.
Searching through the forums here I see that the code generally pertains to the cat converter, is there anyway to confirm this? I have heard that in general issues with the catalytic converter tend to be very obvious. Also I have seen the de-fouler/anti-fouler setups, but dont trust myself enough to do that. Are the o2 simulators a good way to go? I'd be worried about missing future issues in using a simulator.
As far as I can tell there are no issues with my car at the moment in terms of it runningn, no noises or odd behavior. Its a civic ex 02 1.7L. Just replaced both o2 sensors with Bosch brand universal fit sensors (saw another thread about OEM sensors still throwing the same codes?)
Thanks a lot ahead of time.
Brian
Old Aug 30, 2010
brians02ex's Avatar
Re: P0420 code with some history
Sorry posted same question twice by accident.
Old Aug 30, 2010
lazlong's Avatar
Same thing happened to me. It's the cat. Sorry bro.
Old Aug 30, 2010
brians02ex's Avatar
Lazlong,
Did you do a full replacement? I'm not sure if it was from your thread or not, but did you have a crack?
Any thoughts on going with the de-fouler or simulator?
Thanks!
Old Aug 30, 2010
lazlong's Avatar
Yes, I replaced the cat. Found someone on craigslist who was selling theirs. I have no idea about de-fouler or simulator.
Civic15
18
Sep 19, 2017 07:48 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
jessica19699
Jul 29, 2015 05:51 AM
Green02civic
Jul 27, 2015 10:48 PM
viperGTS
Jul 27, 2015 08:40 PM
