2002 Civic - No power to power window fuses
Old Jul 21, 2010
civicguy77's Avatar
civicguy77 is an unknown quantity at this point
I have a 4 dr Honda Civic, I've been haveing this problem for over 2 years, lived with it, but now its getting pretty hot and i have to fix this now. For the past 2 years the power window fuses have been blowing my fuses and now that i tried to change them again, and i get no power to the fuses, please help!!!! What should i do, whats the next thing i should check for ??
Old Jul 21, 2010
02civicsi02's Avatar
Low and slow!
Re: 2002 Civic - No power to power window fuses
If it blows the fuses for it then are you using the right size first off. If you use the right sizes then try using alittle bigger fuse for it and see how that does.
Old Jul 21, 2010
civicguy77's Avatar
But like i mentioned before, now i dont get ANY power at the fuses for the power windows. The fuses had power yeserday, and now theres no power what so ever!
Old Jul 23, 2010
civicguy77's Avatar
Found the issue!!! There is a power window relay in the engine compartment relay box, changed it $5.00 Auto Zone and replaced the Window Control Switch $5.00 Junk yard. Now i can feel the breeze!!!!
Old Jul 27, 2010
mando_vzl's Avatar
mando_vzl is an unknown quantity at this point
Do you know if there is a relay for the front and one relay for the rear? or is it one rely for both? My back windows dont work for a while now.
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
15
Nov 8, 2001 05:06 PM
2k2CivicEX
Nov 5, 2001 07:22 PM
