P1361-Manuf. Cntrl Ign. Sys. or Misfire
Old Jul 14, 2010
So.CalDiddy01EX's Avatar
So.CalDiddy01EX is an unknown quantity at this point
i just got back from a trip from which my '01 civic (v-tec) basically tried to die on me in the middle lane of the freeway at about 80. its a hundred plus degrees and i was goin uphill with the A/C on. i pulled over and let the car sit for a half hour or so and it had no problems driving the last 15 miles or so home. water and oil are at acceptable levels. there are no obvious sounds of mechanical problems and appears to drive normally. the check engine light is still on and the P1361-Manuf. Cntrl Ign. Sys. or Misfire code comes up. is this signs of something serious? i really dont have the money to get it checked out at the moment and am desperate for any advice.
should i not attempt to drive it until it gets checked out?(which is not likely anytime soon).
any help would be greatly appreciated,thank you in advance
Last edited by So.CalDiddy01EX; Jul 15, 2010 at 02:14 PM. Reason: not exact reading
Old Jul 15, 2010
Re: P1361-Manuf. Cntrl Ign. Sys. or Misfire
freeze frame readout:
throttle pos.- 41.1%
engine rpm- 3504rpm
load value- 84.7%
map sensor-86 kpa
coolant temp-203 F
intake temp- 125 F
short term fuel trim 4.6%
long term fuel trim -3.4%
vehicle speed-73 mph
fuel system 1- clsd
also the light is no longer lit
Old Jul 16, 2010
black28's Avatar
black28 is an unknown quantity at this point
i have a SOHC, but this may be your problem.
https://www.civicforums.com/forums/7...nt-w-pics.html
did you erase the code when you checked it? that prolly turned the light off.
Old Jul 16, 2010
thanks for responding. i def appreciate the help and am trying to get someone to help me with the tutorial you provided(way over my head,and capabilities).
i did not clear the code. i just tried to see if it was a bad connection and tried to adjust it. it just didnt light up the next morning when i restarted it. all signs point to the sensor.
thanks again for the help
Old Jul 17, 2010
black28's Avatar
no probs, let me know how it goes. car trouble aint fun, unless you have nothing to do. haha but like i said mine was a SOHC non-vtec, so it might be different, but should point you in the right direction.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
