antifreeze flush
Old Jul 10, 2010
joetab24's Avatar
joetab24 is an unknown quantity at this point
antifreeze flush
Had my 04 Civic inspected @ the end of March and the dealer mentioned having the antifreeze flushed. The car has 41K miles on it. The cost was $70.00. How often are you supposed to flush the antifreeze? thanks for your help
Old Jul 10, 2010
Re: antifreeze flush
usually every 5 yrs with the honda coolant being used.
Old Jul 11, 2010
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Considering the cost of coolant is pretty darn cheap, and the job is easy, just do it yourself! Go out and buy some coolant, Prestone is good, mix it 50/50. Take your lower radiator hose off the radiator and let out all that coolant. Once it's done draining re-connect the hose and fill 'er back up. Of course this method leaves a little old coolant in the motor but who gives a ****, 95% of your coolant is now fresh and you spent a whopping $15 on a gallon of coolant.
Old Sep 1, 2010
DevilDogDoc's Avatar
DevilDogDoc is an unknown quantity at this point
My 03 manual says the first coolant service is at 100000 miles sounds a screwing raking place...
Munzy
21
Oct 7, 2015 07:48 AM
cferry7
Oct 3, 2015 04:33 PM
rnaodm
Sep 21, 2015 12:42 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
tooly145
Sep 5, 2015 01:05 AM
