Two Spun bearings help
Old May 13, 2010
lucke3er's Avatar
lucke3er is an unknown quantity at this point
2001 honda civic black 155xxx miles.
Always had my car serviced on time. This time it must of had a leak It still had two thousand more miles left till its next oil changed and there was none and I had no clue till I got a knock in my engine. So I got it home towed it too the garage.
Dropped the oil pan took out all the bearings main and rod.
Two bearings were spun rod 1 and 4 or maybe 2 and 4 can't remember.
The crank has a micro scratch on it where the first bearing spun. I'm thinking that you could almost polish it with your finger and a small pad or maybe even sand it lightly.
You think its safe to just replace the bearings?
Where Can I get a set of main and rod bearings with oil pan gasket? Can I order these parts from my local Honda dealer? Thanks guys.
Scout1
Oct 5, 2015 01:33 PM
Bonobo
Oct 2, 2015 06:58 PM
Elciteeve
Sep 28, 2015 12:40 PM
speedlever
Sep 24, 2015 07:18 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
