Idles takes a while to go down
Old Jan 29, 2010
boosted2cam's Avatar
boosted2cam is an unknown quantity at this point
I searched and cleaned iacv still have this problem..
the car idles fine. warm up and after
but when i rev it up a little it stays at like 1500 rpm for like 3-5 secs then drop down to like regular 800 rpms. i guess its geting stuck or something? i checked the cables its loose. i even rev it from the engine bay. (i barely tap it and it'll do it...)
any ideas?
Old Jan 29, 2010
02civicsi02's Avatar
Low and slow!
Re: Idles takes a while to go down
The main problems for a car to idle differently is an o2 sensors, the iacv (idle air control valve, a vacuum leak, or it is the tbps (throttle body position sensor). If you dont have a check engine light on then its not the o2 sensor so now its either a vacuum leak or the tbps. You also have to take in that you may have cleaned the iacv but sometimes thats not always the problem you might need a new one.
Old Jan 29, 2010
Yeah I dont have a CEL.
Might be a vacuum leak..i can hear a big suction or something..ill check that tonight.
then if it doesnt fit it ill buy a new tbps.
Old Jan 29, 2010
yeah you always need to do the idle learn procedure after cleaning intake components like tb and iac. otherwise yes the rpm will seem to get stuck when revving and letting off the gas. make sure throttle cable isnt too tight (it needs 1/2 inch of play in and out). other than that it could be a gasket leaking air if you reused the old ones. but most likely needs to relearn the idle. check this thread at the bottom.
https://www.civicforums.com/forums/7...e-up-mods.html
Old Jan 29, 2010
Low and slow!
Just let us know how that goes, always happy to help.
Old Jan 29, 2010
Do i really need to do the idle relearn?
Only thing i took out was the motor and did a auto to manual then i took out and cleaned the iac but didnt take the tb out.
It was doing it before thats why I decided to clean the IAC.
I thought you just had to do the idle relearn only when you take the TB out?
Thanks for the help
Old Jan 29, 2010
if you take the iac off, you need to do the idle learn. trust me this happens all the time when i disconnect my battery and forget to relearn the idle. i dont even have to remove anything, it will still mess up and get stuck at hi rpms before falling back down. thats why i hate disconnecting battery unless its for something really important.
Old Jan 30, 2010
Ok i did it but still get stuck around 1500 rpm then drops...
I warm up the car, turn off, pull fuse, crank up let idle for 10 mins, turn off turn back off and drove around the block...
what else can it be?
How can i check for vacuum leak? Will a vacuum leak cause it to stick like that? I figure vacuum leak would be cause it to go up and down...
throttle cable is loose so i know its not that
Thanks
Old Feb 3, 2010
Old Feb 3, 2010
you may need new TB/IM and TB/IAC gaskets. the old ones may not be sealing properly. either that or iac wasnt cleaned well enough or has a mechanical problem.
Old Feb 3, 2010
let me try to clean the iac again...
When you pull the fuse do you have to wait like 30 secs? or just pull then put right back in? the battery stays connected?
Old Feb 3, 2010
you just pull the FI ECU fuse for a few seconds yeah. battery can stay connected.
beneditti
Jan 15, 2016 12:31 PM
blaketippett
May 29, 2015 08:02 AM
crowtoo
May 11, 2015 06:50 PM
Ninetyatecivic
May 9, 2015 07:48 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
