2001 Honda Civic Windshield Wiper Issues
Old Jan 29, 2010
ViLLainZ's Avatar
ViLLainZ is an unknown quantity at this point
I poked around a bit but didnt find anything so hopefully this hasnt been posted before. My wiper blades have gone off track and just not sure what it is. They will stay on track but then they will either start slamming the bottom of the windshield or the frame on the drivers side. I tried adjusting the wipers thinking maybe the bolt came loose but if I do this it either slams the frame more or the bottom of the windshield again.
Im just wondering if its potentially I can fix myself or will I have to take it to a shop. I will note my expertise at electronics ends at hooking up a gaming system to a TV haha
Old Jan 29, 2010
CraigW's Avatar
Re: 2001 Honda Civic Windshield Wiper Issues
You might check the nuts under the black rubber caps, They may have worked loose. Don't over tighten.
Old Jan 29, 2010
02civicsi02's Avatar
Low and slow!
^^^ This is probably your problem, the wipers are probably just loose so just tighten them and see if that works.
Old Jan 30, 2010
ViLLainZ's Avatar
I did lift the rubber caps and messed w/ the bolts but the problem continued. Could this potentially be a "motor" problem? is there a motor that runs the wipers? could they be shot? Thx for the replies thus far
Old Jan 30, 2010
CraigW's Avatar
I remember someone on an Accord thread once said that the tiny grooves cut into the wiper arm base where it goes over the 2 protruding mounting shafts where worn down and it was unable to grip tightly and they would slip.
Old Feb 13, 2010
ViLLainZ's Avatar
Ill take a look at that thank you
Old Sep 28, 2010
ngoman's Avatar
ngoman is an unknown quantity at this point
I'm having the same issue with my 2003 honda civic. Would you mind letting me know how you fixed it? Thanks!
Old Sep 18, 2011
KingArthur's Avatar
KingArthur is an unknown quantity at this point
Did anyone get this problem fixed? I too have a 01 Civic and the passenger side wiper is slamming down on the plastic at the bottom of the windshield. This is real annoying and need to get something done.
Old Sep 18, 2011
you need new wiper arms, and possibly the base where it mounts. its due to the gears getting flattened and not able to hold the wiper in one position. so it slips and goes off the window.
Old Sep 18, 2011
KingArthur's Avatar
Thanks, I check the base of the wiper arm and it had a wore spot on the spline. I put some teflon tape around gear on the car, aligned the wiper are alittle higher then put a washer on top, then put the nut on...good and tight. I hope this works.
Old Sep 18, 2011
it should last for a while, but eventually the tape will wear out and back to the same problem.
LionSpratt
Jan 29, 2017 11:07 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
locozoko
Apr 6, 2002 09:00 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
