Weird problem with my '04 Civic LX
Hi,
I have a '04 Civic LX with automatic transmission and 68K miles. Recently, my car has started to vibrate when I put on the brakes to stop. The vibration is quite vigorous when I start out but it decreases a lot after I have driven it for a while (say about 10-15 minutes). Also, it has now started to vibrate when I put the car into reverse gear. I took it to a Honda dealer and they said that it is normal and could happen because of the cold weather or using bad gas (which didn't make sense to me at all cause I have driven it before in even more severe weather and I always use BP). Also, sometimes when I try to accelerate, it takes a couple of seconds before the car actually accelerates.
Do you think it might be a problem with the fuel injectors and the engine is not getting enough gas? Should I use some additivites in the gas tank to clear out any deposits which might have formed? Or do u think it might be some problem with transmission? I hear sounds when I change the gear to reverse (which I assume is the auto transmission changing gears). They also checked the rotors and brake pads and said both are fine.
Thanks in advance!
Thanks in advance!
Re: Weird problem with my '04 Civic LX
might be a bad engine/trans shared mount in the front. by vibrating, do you mean just shaking, or is the rpm going too low. might need new spark plugs too, maybe its misfiring.
tylerginevan
Apr 27, 2015 12:29 PM
cdt12271
Apr 23, 2015 11:36 AM
SSMatey
Apr 13, 2015 06:09 PM
