Temp Guage, Fans dont work and lights
sup everyone
my tempe guage aint working or the fans...so i dont know if the car is over heating or not...
I checked all fuses...
another thing my power dr locks and cluster lights dont work when the key is out...it has power when i turn the key once...
With the key out i can still turn the headlights on but my cluster light doesnt come on unless the key is turn once...
i just did a auto to manual swap...so it might be some kind of wiring problem
thanks!
thanks!
Re: Temp Guage, Fans dont work and lights
1. check ECT (engine coolant temp) sensor above thermostat in the engine, that sends the signal to the temp gauge.
2. check the fan sensor which is poking inside the thermostat housing. that tells the fan when to turn on when coolant gets too hot.
3. check the fan relay (not fuses)
4. check the cluster wiring for shorts or loose wires. when the park lights are on, try turning up the dimmer **** (it could be on low).
now just the temp guage on my cluster aint working and the fans aint working...i turn the a/c on and the fans still dont come on...
how do you check if the sensors are good?
how do you check fan relay?
wheres the fan relay?
Where the sensors?
any pics
Thanks bro
fan relay is in the under hood fuse box, it says which one in the owner manual. have you tried supplying power directly to the fans to make sure they work?
if you have 01-05 civic, here is how to test the sensors. there is no test procedure in the manual. but what i would do is remove it, then put the tip in various degrees of water. like one cold, one room temp, one hot. measure the resistance in each liquid and you should be getting different resistance readings each time (use multi/ohm meter). if readings are the same, sensor is bad. for the fan sensor, there is no way to really test i dont think, aside from first supplying power directly to the fan. it could also be the relay gone bad or something with the wiring. or it could be it just needs a new fan switch/sensor.
for the fan, check number 4 and 14 fuses in underDASH fuse box. remove fan relay from underHOOD fusebox and test it. the fan relay is a normally open type A relay. connect power and ground to number 3 and 4 terminals of the relay, then test for continuity between number 1 and 2 terminals. if no continuity, replace relay. when power is disconnected from number 3 and 4 terminals, there should NOT be continuity between 1 and 2 terminals. now go to the fan relay "connector" socket in the under hood fuse box. measure the voltage at the number one terminal with a multimeter. there should be +12v. if not, the fuse box must be replaced. if there is power, get or make a jumper wire and connect the number 1 and 2 socket terminals together. the fan should now come on. if it works, remove the jumper and turn the ignition to ON, without starting the motor. check voltage at number 3 terminal of socket. if no voltage, its a wire issue between the two fuse boxes. if there is 12v, turn car off and reinstall fan relay into the socket. now go find the fan sensor in the thermostat assembly and unplug the connector harness. jump the two terminals together and see if the fan turns on. if it does, you need a new fan switch. if it doesnt, you have a wiring problem going to the switch. to test the fan switch, put it in boiling water and measure continuity between the two terminals of the switch. there should be continuity. in room temp water, there should be no continuity.
17 is the ECT water temp sensor, at the top of the engine near the thermostat. the fan sensor is angled down and is actually inside the thermostat bulb housing, number 16
I will try it tomorrow, wonder why the fans dont come on when i turn the a/c on...a/c dont work by the way..
yes i have a 02...
oh so take the sensor out and hook the meter to the sensor?
yes i have a 02...
SO if the ECT sensor is bad...my temp gauge cluster would sit on C like that?
is there anyway i can see if theres even signal going to the cluster?
ECT is basically a temperature sensitive resistor. depending how hot it gets, it sends different readings to the cluster and also the ecu. are you having any idle or warmup issues? cause thats a sure sign of a bad sensor. you may also want to make sure the gauge wire is not loose or anything by jiggling around the wiring. im not sure how you can test the sensor, i dont know the logic it uses to communicate with gauges. but there is a gauge test mode you can do to make sure the cluster isnt bad. it will sweep all the needles on auto and if the temp gauge still doesnt move, you know the temp gauge is the problem and its time for a new gauge cluster.
The gauges have a self diagnostic function
check fuse #9 in underhood fuse box and #10 in under dash fuse box.
1. push and hold trip reset button
2. turn the lighting switch on
3. turn the ignition switch ON (do not start engine)
4. within 5 seconds, turn the lighting switch off, then on and off again.
5. within another 5 seconds, release the trip meter button, then push and release the button 4 times repeatedly.
notes: diagnostic mode ends when ignition is switched off or vehicle speed exceeds 1mph.
all gauge needles should make a full sweep from min to max and back again. beeper sounds 5x, indicator lights flash, segment display flashes 5x. pressing the trip meter will restart needle sweep.
ok the fans work when i connect them to the battery.
I did that cluster test and everything works. it does say error tho but the temp gauge did move.
if my a/c dont work will the fan stil come on when i turn the a/c on? blower and everything still works
depends, i think sometimes the fans will not come on if there is a problem with the compressor circuit. did you do any of the other tests to see if its a fan sensor or wiring? what do you mean the cluster test says error? in the lcd part? thats a serious problem, it means the communication line is faulty. it should be reading 88888.8 if everything is fine. Error code means there is a malfunction between the gauges, the multiplex unit, and the ECM. If there is any failure of the diagnostic tests, the cluster must be replaced. and hopefully that will fix the problems.
so is it the cluster or a wiring problem?
I havent gotten a change to do the test for the switches and sensors...
right now its a cluster issue for the temp gauge. if it says error, you should replace it. check ebay and try to find one that matches your current mileage. but for the fan, it may be the fan sensor or wiring or relay.
I forgot to mention im using k-tuned immoblizer bypass...it disables the Multiplexor if that matters...
u sure its the cluster? the needle moves for the temp gauge...
Thanks man
Thanks man
ah okay nevermind then. i bet thats the reason. did your coolant gauge stop working when you installed the bypass? it may be related. i think cluster gets its coolant temp reading thru the ecu and multiplex unit, and ecu gets the info from the water temp ect sensor in the block. if it says error, there is def a communication problem and that is prolly why the temp gauge wont work (it moves for the test, but its not receiving data from multiplex unit).
naw the coolant gauge worked before i did the auto to manual.
so the communication error is due to the bypass thing?
reason why i bought the bypass is because honda couldnt reflash the ecu...or some ****...what i do now?
should i unhook the bypass and try to do the diagnostic test? well wait i wont be able to turn the ignition on...damn
wonder how people get away with it using the ktuned immoblizer bypass for their k20 swaps
well if my Multiplexor is disable wouldnt my power dr locks etc wouldnt be working?
i called k-tuned they told me well you shouldnt have installed it on a car with a Multiplexor...they said its made for older civics...i said well it says on your site its made for 02-04 D&K series ecu...why would you use a 02 d series ecu in a older civic anyways?...they should make that more clear
can i call the lock smith to come and try to reflash the ecu? or reprogram me a new key?
lol wow. a locksmith can prolly make a key and program it yes. not reflash the ecu, only honda dealer can. so basically you want a key that works with the stock ecu? im pretty sure the bypass is causing the problem tho. im surprised you dont have more issues.
theres 4 wires on the bypass thing...2 of it goes to whatever i forgot lol..but the other 2 is for immobilizer and multiplex...i just disconnected the one for the multiplex and it worked!
Did the self diagnose test again it was fine. Waited like 30mins before the fans came on. so everything is good
Now its my battery...its either my battery or my alternator. If the alternator is out wouldnt the battery light come on?
I checked the battery while the car was running...it was like 9v...shouldnt it be like 14?
And when the car is on when i press the clutch in i hear like air coming out or something from the engine bay...weird...
Thanks for all the help man!
wow nice so the temp gauge works now? about the battery, what does voltage read with car off? and yeah the battery light only comes on when alternator is bad. but it might be slightly bad and not producing the full 70amps. ive seen some that still put out 30-40 amps so they technically still work but not enough to power the car and charge the battery. i would just get a test at the auto store. sounds like battery but you should be getting 14v with car running. make sure you have a good connection when youre testing. check the battery with car off, and then try charging it with a slow amp trickle charger. they sell em at auto store for around $50 and its well worth it. charge up the battery to full 12.6v and see if it holds charge.
i brought the battery to autozone the other day and they said it was good and they fully charged it but it died after awhile since i was messing with the car trying to get it to start
I have a 10amp battery charger but i dont know how long to charge it for?
so charge the battery (disconnected from the car) then elave for couple hrs and see if its the same voltage?
get a trickle charger like a 1amp and leave it hooked up til the charged light comes on. it takes longer but will not ruin the battery. then wait a few days if you can and see if the voltage drps down from 12.6v. did you get the alternator checked?
naw havent droved the car yet. do i just bring it to autozone and they can check the alternator?
yeah their machine should be able to check it on the car so long as battery is charged. kragen will do it too. advance auto has the best setup if you have a store nearby.
crowtoo
May 11, 2015 06:50 PM
hokiedad4
May 3, 2015 10:06 PM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
