Timing Belt replaced, now it's knocking
Old Dec 11, 2009
Mudd's Avatar
Mudd is an unknown quantity at this point
03 LX auto, 4 door if it matters or you care. Had the timing belt done at a local shop, as it was time (108k). After I got it back, I noticed the engine is generally louder than it was previously, but I chalked it up to new parts needing to break in (tensioners, water pump, crank and cam seals were all done at the same time).
Now I notice that, in addition to the engine being a little louder in general - and by that I mean nothing in particular is louder, just the entire engine - it's knocking during acceleration. I'm wondering if maybe timing is off by a degree or something, or if there's anything stupid I should look at / for before taking it back into the shop. Mileage doesn't seem to be affected at all since the timing belt service, so I am hesitant to think timing, but I don't know what else it could be. I've now put around 1000 miles on it since the service, I think that's plenty of break-in time.
Any suggestions?
Old Dec 12, 2009
CivicAK's Avatar
CivicAK is an unknown quantity at this point
Re: Timing Belt replaced, now it's knocking
they warrent there work so ask them what they screwed up. And seriously slap em if they tell you its something they never touched.
Old Dec 13, 2009
roger449's Avatar
roger449 is an unknown quantity at this point
second that
Old Dec 23, 2009
wardhaines's Avatar
wardhaines is an unknown quantity at this point
Sounds like the timing got advanced.
When realigning the cam and crank pullies just being one tooth off will either advance or retard the timing slightly.
Try higher octane gas to see if the ping goes away.
Old Jan 4, 2010
sikomaniac's Avatar
sikomaniac is an unknown quantity at this point
bad timing also can cause your catalytic converter to go bad. huge PITA for us in California. if you have emissions regulations see if they will replace that for free too. =P
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
sharp66
31
Jun 12, 2022 08:45 AM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
