aftr market dash
to get the d.d. dash to work in my car i need the following info i believe all the wires are in the molex connecter attached to the stock gauge cluster..
the vss wire color and ppm.
the tach wire color, and normal or low voltage 12v or 5 volt.
the water temp sender wire color.
the oil pressure sener wire color.
the fuel sending unit.. wire color
the check engine wire color.
the ebrake wire color.
the cruise control wire color.
the hi beam wire color.
the low beam wire color.
the right turn signal wire color.
the lefte turn signal wire color.
any help would be greatly appriciated.. thank you..
Re: aftr market dash
here is all i have. some are not exactly as you are wanting. the headlight circuit for example. anyway this should help. hopefully you have 04-05 civic with new cluster. if you have 01-03 lx/ex or 01-05 dx/vp, i need to find old diagrams then. lemme know.
okay those diagrams wont work. you have the old style cluster right? with the regular backlight, not the new LED ones with blue or red rings? lemme try and search for the old ones.
ricer_em2
May 11, 2016 08:09 PM
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
