Glowing Exhaust Manifold
Old Oct 18, 2009
sortsa77's Avatar
sortsa77 is an unknown quantity at this point
I posted this on General with no replies so here goes.
We had the timing belt and water pump replaced about 2 weeks ago for routine mtce on a 2002 DX. The other night the car started running really rough, the engine light came on and when the hood was opened the exhaust manifold was glowing red. Next morning you could see a very small crack in the ex manifold. I was told it was the cat so I replaced it and the car ran fine on a 5-10 mile trip. My son jumped in the car after it had been off for a couple of hours and in about 1/2 mile the same problem happened. I haven't looked at it, waiting for first light. Could it be a bad O2 sensor?
sortsa77
Old Oct 18, 2009
seoul4korea's Avatar
seoul4korea can only hope to improve
Re: Glowing Exhaust Manifold
Well if you manifold was that hot more then likely you burned you O2 sensors out. What else happened to the car? Did you run your check codes?? Some thing is happening to increase increase combustion temps?? are you running learn.
Old Oct 18, 2009
sortsa77's Avatar
No fault light now only comes on when engine begins to stutter. I will take in to the mechanic on Monday as I assume the error code, if there was one, will still be in the memory.We checked and there are no visible cracks. Disconnected the upper O2 sensor and seems to be running fine. I'll replace it with a new sensor and see what happens. I'm wondering if a faulty sensor could have loaded extra fuel into the engine and have some unburnt fuel igniting in the exhaust manifold. (?)
Old Oct 18, 2009
sortsa77's Avatar
Just got the codes: 1362 TDC Signal, No Signal. When it started getting hot again, I disconnected the upstream O2 sensor and it seems okay. Now I don't know which to replace.
Old Oct 18, 2009
I would do the TDC first. hows the o2 look?
Old Oct 18, 2009
sortsa77's Avatar
FIXED!!!
The error code was correct. The TDC ( cam sensor) was sending erroneous info. Replaced it and all is good. It seems it is not uncommon for this failure to occur when the timing belt and / or water pump are changed. Hmmmm.
Old Oct 18, 2009
sortsa77's Avatar
FIXED!!!
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
jdh022764
18
Nov 3, 2015 06:44 AM
TheRiddicles
Sep 21, 2015 03:34 PM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
