when do u change your spark plugs?
Old Oct 12, 2009
briain02's Avatar
briain02 is an unknown quantity at this point
At what kind of miles do u change your spark plugs? Book says 110k, is this realistic? The plugs are damn expensive. I'm at 60 k, runs good. Should I change them?
thanks
Old Oct 12, 2009
Re: when do u change your spark plugs?
no its not realistic. and the stock platinum plugs are suck anyways. they only use em to extend the change interval. i would change them at 60k yes. you can go with ngk v-power copper plugs which perform better than the platinums and only cost $2 each, but they will not last as long. maybe 2-3 yrs tops. but theyre so cheap if you dont mind changing more often, go with those. or if you have $$, get some iridium ngk or denso those will perform the best by using less electrical energy and they usually last 4-5 yrs. i would never run platinums in any car unless you dont care about performance or the plugs are very hard to change. on our cars, it takes about 5 mins to do all 4.
Old Oct 14, 2009
01civictune's Avatar
01civictune is an unknown quantity at this point
What would you say about Pulse Plugs ? I have heard mixed things
Old Oct 15, 2009
complete garbage. i posted a few times about them already. $100 for something that has a high fail rate, has ruined plenty of engines, and performs worse than $2 copper plugs. i used it for 10 mins, it made my engine make some very strange growling sounds and i could even feel the hp loss. i sent them back right away and had to wait a month before finally telling them im doing a chargeback to the credit card and they refunded me. very hard to reach on the phone, and they have horrible customer service. i hope they go out of business. this is the worst fail ive ever seen in the spark plug world.
thana
Jun 15, 2020 07:05 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
Micks2K1
Dec 10, 2001 07:11 PM
