Temperature gauge pegged at H
Re: Temperature gauge pegged at H
right now it sounds like a water pump issue, but could also be the head gasket if you let it run while the gauge was hot. overheating will definately blow the gasket.
thats guys i appreciate responses, if water pump was bad would i have to keep adding water to it ? because i dont see any leaks, maybe i should get a pressure test
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
260000milesgoal
Sep 25, 2015 07:41 PM
david34
Sep 23, 2015 11:13 PM
