Gas Pedal Sticking
Old Aug 18, 2009
rdsanti's Avatar
rdsanti is an unknown quantity at this point
Gas Pedal Sticking
Hi. I have a 2003 civic DX and I have a problem with the gas pedal. The pedal is a little hard, and when you go to press the pedal, you have to give it a little force to start moving the pedal. It's not easy to start the accelerating slowly. I read on the Internet that some people have experience this problem on other cars and their problem is that the throttle valve gets gunked up with carbon deposit. I looked at my throttle valve and it has something that looks like carbon, I think. I was wondering, does the throttle valve have to be clean and the walls?
Old Aug 18, 2009
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Re: Gas Pedal Sticking
It sure wouldn't hurt to take some throttle body cleaner or seafoam, doust a rag and wipe that badboy down. Open the butterfly and clean the edges of it (the blade looking thingy) and make sure you clean the walls of the throttle body where the butterfly is going to be closing. See what that does for you.
Old Aug 18, 2009
rdsanti's Avatar
Is it easy to remove the intake?. I think is more easy to clean outside. On the internet it says to use carb. cleaner and I don't know if the carb. cleaner gets inside the engine could damage something. Any tips?
Old Aug 18, 2009
It's very easy to remove the intake, carb cleaner prolly won't hurt but some might object to that. I'd use just about anything on mine
Old Aug 19, 2009
rdsanti's Avatar
My whole intake is covered with some black stuff. Is this normal?
Old Aug 19, 2009
I give up
Old Aug 19, 2009
Protan988's Avatar
Protan988 is an unknown quantity at this point
Yes it is normal for that to happen over time... just clean it out and your throttle sticking should stop. Just get throttle body cleaner. That is what it is meant for..
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mikebj23
Jul 28, 2015 08:08 PM
shaejb15
Jul 27, 2015 03:48 PM
wootah88
Jul 21, 2015 10:22 AM
Trennytrent
Jul 10, 2015 09:01 PM
