The strangest thing
Old Jul 10, 2009
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
The strangest thing
So pullin the car outta the garage(engine Cold) i noticed some drips on the ground (4 to be exact). Parked it and went to check it out. It felt and looked like coolant. So decided not takin the car today for work and i grabbed my bike. As im leavin i look at my car and see a trail of waterish liquid coming out. So got home from work and pulled the car back in the garage and popped the rad cap off. Its full looked at over flow tank its a little low under the full line. let it run until it got hot turned the a/c on to get it hotter. Looked under the car and not a drip felt under the chassis and looked around and i can see any signs of coolant so WTF?? I think i might have the ghost of a piece of crap car fused with my car
Old Jul 10, 2009
Re: The strangest thing
you sure it wasnt water from the a/c system dripping?
Old Jul 11, 2009
Foffie's Avatar
positive cause the ac wasnt on in my garage or the day/night prior to it. And it was green
Old Jul 12, 2009
ozzy's Avatar
ozzy is an unknown quantity at this point
if its green, logic would say coolant to me? if you looked around the bottom and it seemed dry, try a coolant passage higher up that has a clear path to the ground. Do you have your stock splash shield on?
Old Jul 12, 2009
Foffie's Avatar
nope that thing didnt last long with a lowered car but havent seen coolant again so if it aint broke dont fix it i guess
Old Jul 12, 2009
might be seepage from a hose or around water pump. only way to know is jack the car up and look.
Misfit2613
Jul 30, 2015 09:49 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
robbie374
Jul 7, 2015 02:56 AM
