01 civic lx Car Uneven Suspension.
Re: 01 civic lx Car Uneven Suspension.
Lose some weight. But seriously I bet you drive the car a lot by yourself so there is never any weight on the other side. Mine sits a little higher on the right side too.
no car is perfectly even on both sides due to weight balance, etc. what does it look like with you in the car?
I had that problem as well when I was on the spring/strut combo. Don't forget that the engine is more on the driver's side as well. But since I bought the coilovers, I've been able to adjust it so that it's even.
Coilovers will allow you to adjust the height at each wheel, and the dampening/rebound.
+MM+ --the engine might be more on the drivers side, but the transmission is all on the passenger side.
